1969 Headlight Assembly Adjustment ?
Old Nov 20, 2002 | 05:29 PM
James's Avatar
James
Default 1969 Headlight Assembly Adjustment ?
I have my headlight assemblies all rebuilt and installed back in the front end.
I have the opening and closing adjustments done and the front to back and side to side adjustments made.
My question is that one side of the door sits a lower in the opening than the other side. Not much maybe a 1/16 to a little less than an 1/8.
Can you adjust one side to come up a little more than the other?
I know how to adjust the hole unit but I just need to make final tweek on one side of the assembly so the door sits nice a level in the opening.
Any ideas?
Old Nov 20, 2002 | 10:35 PM
jwbert's Avatar
jwbert
Default Re: 1969 Headlight Assembly Adjustment ? (James)
Shim the mounting on the opposite side or grind a litte off the mounting on the side that's low, which would raise it in the opening????? :confused:
Old Nov 20, 2002 | 10:44 PM
lbell101's Avatar
lbell101
It depends on how it sits. If it's just the front corner, then shim that side under the front mount. If the whole side is low, then loosen the pivot mount (3 bolts on the pivot bushing housing) and adjust.
Old Nov 21, 2002 | 09:17 PM
WATTAC's Avatar
WATTAC
Actually there's four or five adjustments on the headlight assm. But I wouldn't start changing them without a manual. They allow you to change just about every aspect of the door, including where it is when it's opened and where it sets when it's closed. I'm not sure how the factory did it, but now that the car is finished getting to most of these adjustments will take time and long arms up underneath the front of the car.
And a word of caution, proceed slowly, one mistake and the doors will take the paint off the edges of the openings or crack the fiberglass as they open and close.
Look around for a good manual or someone who's done this before to help you.
Andy
Old Nov 22, 2002 | 08:24 AM
James's Avatar
James
Default Re: 1969 Headlight Assembly Adjustment ? (WATTAC)
Thanks for the tips.
I have a good manual that shows all of the adjustments and how disassemble and reassemble.
I will have to go through it a little more.
I just need to make a fine adjustment in each corner on one side only.
I will try to mess around some more this weekend.
To 1969 Headlight Assembly Adjustment ?
