Need a new radiator - help!
Old Feb 29, 2020 | 12:11 PM
Mpls Funk's Avatar
Mpls Funk
Default Need a new radiator - help!
Hi all,
I pulled my radiator (1970 350/350, no A/C, manual transmission) as part of pulling the motor for rebuild. I took it to a radiator shop to have them check it out and they found many pin holes and said it's really not salvageable. So I need some advice on where/what to buy a new one. I would like it to be very close to original. I will never have the car judged, but it is a numbers matching car. While I'm doing some small mods/upgrades during the rebuild, I'm not going crazy with it. So I would like a radiator that is very close to original, or if there is something that is slightly better? But I'm not wanting to have to do modifications to the car to get it to fit, etc. Make sense? Any recommendations would be appreciated!
Old Feb 29, 2020 | 12:50 PM
20mercury's Avatar
20mercury
Default DeWitts
Originally Posted by Mpls Funk
Hi all,
DeWitts is the way to go. And your timing is impeccable, great sale today!
A little more but very well worth it!
https://www.corvetteforum.com/forums...year-sale.html
Old Feb 29, 2020 | 01:10 PM
Mpls Funk's Avatar
Mpls Funk
Thanks for the tip! Who can tell me if the original radiator was the "black" type, or the "natural" type?
Old Feb 29, 2020 | 01:30 PM
forman's Avatar
forman
cant they re-core the old one the brass top and bottom must still be good
Old Feb 29, 2020 | 01:40 PM
Mpls Funk's Avatar
Mpls Funk
They are going to look into that, but he said even if they can, it will be expensive. Thinking I might be better off just buying a new one??
Old Feb 29, 2020 | 02:17 PM
forman's Avatar
forman
I got mine done 3 rows for 350 for a bb rad I have never overheated the car ever even in 90 degree heat
Old Feb 29, 2020 | 03:59 PM
jackson's Avatar
jackson
OP
Since you're Not gonna have it judged; suggest shop for quality, good fit and adequate capacity First ... appearance Last.
Seems you're rebuilding a motor ... have you already addressed how you're going to preserve your block stamping IF decking is required ?
Old Feb 29, 2020 | 04:22 PM
Mpls Funk's Avatar
Mpls Funk
Originally Posted by jackson
OP
I was looking at the Dewitts as that seems highly recommended. That appears to be the "exact fit" and proper capacity. I just don't know if the original was a black unit or not? I'm thinking it was a black brass...and so the black aluminum from Dewitts would be a performance and quality upgrade and still look mostly original?
Yes, I address the block stampings with the motor rebuilder!
Old Feb 29, 2020 | 05:30 PM
BKarol's Avatar
BKarol
According to this article, if you believe Richard Prince, semi gloss to gloss black for either copper or aluminum: https://books.google.com/books?id=oD...ration&f=false
Old Feb 29, 2020 | 08:24 PM
sr'71's Avatar
sr'71
Ever wonder where all those micro holes came from ? Look on the drive's side of the radiator frame, outward facing, and see a ground [black] wire . The radiator is not grounded to the auto's frame. [check continuity radiator to chassis ] . I added a ground wire, radiator hold brace to existing ground, after pin hole became a pressure backed leak
Old Mar 1, 2020 | 12:07 AM
OldCarBum's Avatar
OldCarBum
Go with DeWitts, great sale going now so don't think about it for too long.
I also noticed they are offering free shipping.
Old Mar 1, 2020 | 08:13 AM
forman's Avatar
forman
Is that the price 729.00 I would look into a re core .. I know it’s pretty and all but why spend the money when you can get your done for. Half the price
Old Mar 1, 2020 | 09:06 AM
Tom@Dewitt's Avatar
0Tom@Dewitt
Former Vendor
1139070A 599.99 list $510 net with discount
Old Mar 1, 2020 | 09:15 AM
forman's Avatar
forman
Tom I like your products but if someone can save some money and retain some what of a original look I would re-core ,, to each there own ,, I took that price from your website after i punched in the info not from corvette forums
Old Mar 1, 2020 | 09:21 AM
Tom@Dewitt's Avatar
0Tom@Dewitt
Former Vendor
You did right, the black ice coated radiator is about $125 more. I used to paint radiators for $25
Old Mar 1, 2020 | 09:23 AM
OLE442's Avatar
OLE442
From: Way too effing close to the city.......NRA Life Member!
I went with the DeWitts exact fit in my '76 and love it. I left mine natural aluminum finish.
Old Mar 1, 2020 | 09:31 AM
interpon's Avatar
interpon
They wanted 500 for my recore and only one place around me would even attempt it..
dewitts universal fit 2 one inch core solid with ac and 90 plus day..shipped was less..left aluminum color, can hardly see it buried under all shrouding and foam!
i did save my old radiator though..never know..USA made too if that matters
To Need a new radiator - help!
Old Mar 1, 2020 | 09:42 AM
Bikespace's Avatar
Bikespace
Dewitts contracts for Zip to make high quality radiators that fit, but may not be perfect for judging. They are $400- each, vs ~$700.
https://www.zip-corvette.com/instant...a-232%20ra-233
Old Mar 1, 2020 | 09:48 AM
forman's Avatar
forman
Tom are the ones on zips website single core
Old Mar 1, 2020 | 09:56 AM
interpon's Avatar
interpon
see my post 143
https://www.corvetteforum.com/forums...-topics-8.html
its a sticky thread..
mine was two core one inch..had an issue and tom d responded fast even though bought zip..399 bucks like mentioned
but op needs to see what fits his..comes set for auto but i have manual
edit...sorry my name is tom too..i know you meant tom d
here is my 79 install
https://www.corvetteforum.com/forums...nt-79-l82.html
