Remove headrest
Old Mar 2, 2020 | 10:27 AM
Lord Melbury's Avatar
Lord Melbury
Default Remove headrest
Can anyone share a tip about how to remove the headrest from the backseat (69 coupe)
Håkan
Old Mar 2, 2020 | 10:41 AM
terrys6t8roadster's Avatar
terrys6t8roadster
Ya need to tip it laterally to one side then lift up, cannot remember witch side. T
Old Mar 2, 2020 | 03:45 PM
Lord Melbury
Thanks!
Old Mar 2, 2020 | 04:44 PM
VERYSOON's Avatar
VERYSOON
Hej
Wiggle it side to side while pulling up. It takes more upward pressure than you willing to give it at first since it probably hasnt moved in a while. I worked on mine gently, got a bit frustrated and jerked the sob outa there. It will come out!!
If you need to reglue the cover I had great success with Weldwood contact cement.
VERYSOON
Old Mar 2, 2020 | 06:40 PM
Lord Melbury
Originally Posted by VERYSOON
Hej
VERYSOON
Yes I have to reglue the plastic cover at the underside. DonŽt know if I can find Weldwood in Sweden, but I like the 3M products
To Remove headrest
