From: SUFFIELD CT USA 2023 C8 CORVETTE UN-MODIFIED FINALIST
Rough idle and dieseling?
I just installed an ATK 383 crate motor with a Trick Flow 650 carb in my '77. The car wont idle well below about 1100 RPM and diesels?. I used the stock Distributer. There is an exhaust leak just before the right side muffler which I think doesn't matter Any ideas?
did you set the total mechanical advance timing to 34-36 degrees as specified by ATK?
did you check the float levels of the primary and secondary float bowls?
did you adjust the idle mixture screws?
You stated you used the stock distributor but didnt say which one, L48 or L82.
The l48 distributor has 22 degrees of mechanical advance so to achieve the 34 to 36 degrees ATK calls for you would have to set initial timing to 12 to 14 degrees and use non-stock advance springs.
The l82 distributor has 16 degrees of mechanical advance so to achieve the 34 to 36 degrees ATK calls for you would have to set initial timing to 18 to 20 degrees and use non-stock advance springs.
I would be willing to bet the secondary throttle plate is open too far. Trick Flow is like the Holley design. There is a transfer slot in the secondary system that needs to be adjusted for a 0.020 gap exposure. Rather than a bunch confusing paragraphs here, try YouTube for the procedure to correct this. The carb will have to come off and be flipped up-side-down.
Basically the carb is dumping extra fuel even though the primaries are almost closed at idle. Might have a bit too much vacuum advance too.
Float bowls were rechecked. L48 distributor with 12 degrees initial and springs were changed per Lars several years ago. I did not check the secondary clearance issue though. Will get with you tube tonite!
ATK makes several versions of the 383...… which one have you got?
Check all of the things that MelWff said to check and I will add put a vacuum gauge on it and see if the needle is steady. A bouncy needle is an intake or carb leak.....you can sniff out the exact location of the leak with an unlit Propane torch cracked open slightly......a vacuum leak will suck the Propane in and change the idle. This also works awesome for multiple carb motorcycles.....
Are you 100% sure that your vacuum advance is hooked up to manifold vacuum, and tested it with a vacuum gauge?
The idle mixture helped a bit, but what really got my engine cool and stopped the dieseling was setting the timing correctly, and then going back and setting it even more correctly.
Thank you all who responded to this thread
I feel like an idiot but it seems like it may just be float level all along. With the air cleaner off I can see the carb spitting up. I lowered the levels slightly and the erratic idle and running on are all but gone. The cars pulls much stronger also. Should the levels be set with the car hot. Do I need a carb spacer, it's already very tight in there even with a drop down AC ?
Float levels should be set on a warm engine with a fully open choke, there are arrows on the site windows . After adjusting the float level you have to adjust the idle mixture screws.
Carb is spitting? New ball game now.
Your accelerator pump arm is set too tight. Every little vibration is causing the pump to squirt / spit raw fuel.
Using a feeler gauge between the pump shot arm and the linkage, set that gap around 0.012 - 0.15.
More importantly, check it again at WOT, engine OFF. If its too tight, you can rupture the pump shot diaphragm.
You don't know how to make any adjustments to the pump, look on YouTube. Takes two wrenches, very easy to do.
Not true. Both idle & WOT should be checked.
At WOT, damage to the diaphragm if too tight.
At idle, the pump will dribble and cause lots of idling issues.
At idle, if too loose there will be a hesitation or bog off idle.
That's why there is some lee-way; 0.012 --- 0.015.
Holley manuals, Summit Racing video and the like claim 0.015 is perfect.. What the feeler gauge reads at idle (or closed throttle) maybe different than the reading at WOT.
Using a feeler gauge between arm and adjustment screw. There should be some drag with the feeler gauge at 0.015.
However, I have seen videos claiming 0.012 clearance. Less than that and I get a dribble spit, on my Holley 4150 at idle. I assume Trick Flow is very similar.
You will just have to play with it to see what works best for your carb. If its a double pumper, you have to set both pump arm clearances.
But regardless, your carb should not be spitting fuel at idle.
This is a video from Holley. The feeler gauge is only used at WOT. The only mention at idle is that the arm should be in contact with the adjustment screw, no use of a feeler gauge.
You can insist on whatever you believe. but I can vouch that the pump adjustment at idle is just as important as WOT. Some, say its more important and not to worry about WOT clearance.
One adjustment is for preventing diaphragm damage (WOT)
One adjustment is for bog or hesitation issues (closed throttle).
The WOT clearance is seldom an issue. I have never ruined a pump diaphragm. The closed throttle clearance setting assures that a shot of fuel is instantaneous when the primary or secondary throttle begins to move. However, you do not want the setting too tight though or the vibration from the engine, transfers to the pump arm and dribbles raw fuel into the carb causing horrible idling issues.
It takes a steady hand with a feeler gauge to set it just right, making adjustments with two small wrenches. As the feeler gauge is inserted at idle, you will note that a shot of gas will make the RPMs stumble briefly. Persistence and fine tuning will pay off.
