Problems with starter
Old Mar 16, 2020 | 02:27 PM
Red1977Vette's Avatar
Red1977Vette
Default Problems with starter
Hi all,
Yesterday the starter on my '77 was making a very loud clanking or grinding when I was attempting to start it. It had done this before and I took the shims out. After that it was cranking just fine. Until yesterday. I had made sure there was room between the starter and flywheel when I took the shims out - when the shims were in there before the starter was getting bound up against the flywheel.
I should also mention that my battery was dead and wouldn't take a full charge and when it was cranking the starter, it was cranking very slowly. I think I have a bad battery. Could the clanking or grinding be a result of an undercharged battery? Lack of shims or not enough shims? Combination of both? I'm concerned about damaging my fly wheel.
Thanks in advance for the insight.
Charley
Old Mar 16, 2020 | 02:37 PM
MelWff's Avatar
MelWff
With the battery disconnected try to extend the bendix gear with a screwdriver. The tooth gap when extended should be enough to install a typical paper clip.
here is a discussion of the topic https://www.corvetteforum.com/forums...lip-trick.html
Concerning the battery, it obviously is not contributing to the proper engagement of the starter.
Old Mar 16, 2020 | 08:54 PM
jackson's Avatar
jackson
Originally Posted by Red1977Vette
Hi all,
Charley
What kind of starter? .............. Photo?................. Manual trans right ?
To Problems with starter
