Incorrect Master Cylinder ??
Old Apr 8, 2020 | 11:01 AM
Roy W.'s Avatar
Roy W.
Disabled by request 8 JUN 2025
Default Incorrect Master Cylinder ??
I have reason to believe (based on appearance) that the wrong brake master cylinder is installed on my '81 coupe. It appears that the correct one has a rounded reservoir and mine is squared off. (see photo). Now based on repair receipts, this m/c was replaced by the PO and has been on the car for 17 years and 23,000 miles. The brake pedal pressure seems normal and I can lock up all 4 wheels. I have read discussions regarding 1 1/8 inch m/c bores versus 1 inch bores, but remain confused. Question: Should I keep things as they are or order a new correct master cylinder for power brakes ?? What difference might I see with the correct master cylinder??
Old Apr 8, 2020 | 11:38 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Depends on pedal modulation......if it feels fine and not too touchy, then leave it.....nothing to gain.
Jebby
Old Apr 8, 2020 | 12:14 PM
MelWff's Avatar
MelWff
Are there any stampings on the cast iron with a number or name of manufacturer?
Unless you have a desire to make it more original, no reason to change it.
Old Apr 8, 2020 | 12:38 PM
kansas123's Avatar
kansas123
When it comes to brakes on my Corvette, if they work, I don't fix them
Old Apr 8, 2020 | 05:11 PM
bazza77's Avatar
bazza77
looks good works well , why mess with it ?
If your that way inclined you would be looking for all the smog equipment missing as well ?
Old Apr 10, 2020 | 06:57 AM
Edward Ackley's Avatar
Edward Ackley
looks like the 1 I have on my 81
Old Apr 10, 2020 | 08:45 AM
HeadsU.P.'s Avatar
HeadsU.P.
If It Ain't Broke, Fix It Till It Is.
Or.
If It Ain't Fixed, Break It Till It Is.
To Incorrect Master Cylinder ??
