temperature gauge
Old Apr 8, 2020 | 04:28 PM
ray3222's Avatar
ray3222
Default temperature gauge
1972 LT1 had fluctuating needle. Replaced sending unit on drivers side. No luck. Removed green wire from sending unit & connected to ground. Needle went to HOT which indicates a bad sending unit. Should I purchase another sending unit or could there be another problem? Thanks in advance.
Old Apr 8, 2020 | 04:31 PM
carriljc's Avatar
carriljc
Here. Go read this website. Stop buying parts until you do the troubleshooting. You may need the Willcox adjustable resistor, I did, and it turned out wonderful. BUT first you need to determine what is wrong. http://repairs.willcoxcorvette.com/?...&s=temperature
You can specifically go here: http://repairs.willcoxcorvette.com/1...gauge-testing/
But recognize there is a lot of good info on the rest of the page.
Old Apr 8, 2020 | 05:41 PM
MelWff's Avatar
MelWff
Did you put anything on the threads of the new sender?
Old Apr 8, 2020 | 10:09 PM
monstr's Avatar
monstr
Until you get it fixed and to check your gauge when you do Mr Gasket sells a radiator cap with a temp gage on it. Think I will get one too. When I bought mine the gauge wasn't working so I put a new sender in after testing the gauge and wire by grounding the sender connection (pegged) and then opening the circuit (no reading).
Old Apr 9, 2020 | 04:51 PM
ray3222's Avatar
ray3222
No. I saw that would interfere with reading. Thanks.
Old Apr 13, 2020 | 10:06 PM
ray3222's Avatar
ray3222
Thanks carriljc. I was able to solve my problem with your advise.
Old Apr 13, 2020 | 10:11 PM
carriljc's Avatar
carriljc
ray3222
Glad I could help a bit. Way to go. Would you mind sharing so the rest of us can learn?
To temperature gauge
