From: SUFFIELD CT USA 2023 C8 CORVETTE UN-MODIFIED FINALIST
Idle adj. During break in
Those of you with new crate motors did you have to tweak your idle up or down as the engine broke in ? I thought the engine would loosen up and the idle would increase gradually requiring turning it down. The opposite seems to be happening . I had to tweak it up twice to maintain 900 RPM. Does the rings seating and compression increasing cause that ? I only have 200 miles on the '77 with a new 383 stroker.
And yes, if you are wondering if I am OCD at least when it comes to the Vette!
Nah ... not beginning to seize up is it ? Water Temp & OP?
Curious, whose crate is it ?
I have checked for vacuum leaks. I will recheck floats but they were fine. The water temp is 170-175 and oil pressure varies between 30-55 lbs from idle to 4000 RPM. I have only needed to adjust the idle screw maybe 1/8 turn.
Originally Posted by MelWff
Did you adjust the mixture screws?
I have been playing with the mixture screws. The 2 in front were open about 1 turn and the 2 at the back only about 7/8, I marked the original positions when it came back from the shop. The carb is a Quick Fuel Predator 650 and according to the supplied instructions the mixture screws should start at about 1 1/4 turns or 1 1/2 if that doesn't work. So it is setup leaner from the shop then what I would expect from the directions.
Except for chasing the idle a little bit the car starts great hot or cold and runs very strong!
Do you have a vacuum leak, floats adjusted properly?
OK...I rechecked the float levels and found both near the bottom of the windows when they should be 1/2 way up on the arrows of course! They were fine 10 days ago, Just things bedding in? Any way it seemed to idle stronger and I will report back after a test drive. It is Easter and all!
So you didnt try adjusting any of the mixture screws either richer or leaner to see if it effects the idle?
I have adjusted the mixture screws several times that was the point of marking the original settings. If I screwed things up I could at least go back to the exact original settings. I found the fuel levels at the bottom of the windows, they were fine a week ago? I played with the mixture screws some more after that, adjusting for highest idle. I just came back from a thirty mile loop and the idle is still where it was when I left. I am still at the adjusting stage as things break in I guess?
