Ignition Coil Specifications?
Old Apr 13, 2020 | 10:40 PM
Sammy T's Avatar
Sammy T
Default Ignition Coil Specifications?
I have searched, as always, but have come up with a range of specifications for a breaker point coil for a 1969. Members have stated numbers on the the primary side from 1.5 - 2.0 and secondary from 3000 - 20,000. At this point, I am not sure what the true specifications might be.
My current coil, standard replacement style, is 1.8 ohms primary and 6450 secondary. Good? Bad?
Sam
Old Apr 13, 2020 | 10:54 PM
Big2Bird's Avatar
Big2Bird
I "think" there are two types that year.
TI Coil is like 1 ohm, and the other would be higher.
Ideal, regardless of what a book might say, The combo of coil and resister wire should be 4 amperes draw.
Without checking notes, I do NOT recall that specification of the resister wire.
TI is more complicated.
Old Apr 13, 2020 | 10:59 PM
Sammy T's Avatar
Sammy T
You are right, there were two types and fortunately (or unfortunately depending on how you look at it) I don't have the K66 option. I have a minor miss at light throttle and am working my way through all the troubleshooting. All ignition wires are good. Plus are gapped and are correct for the engine and year. Dwell is 30. Cap/rotor are new. Just left with coil and idle circuit (which I set with a vac gauge).
Old Apr 14, 2020 | 08:09 AM
wilcar's Avatar
wilcar
In case you need a quality spare coil,.rockauto has the SMP UC12X Blue Streak for around $26.
Old Apr 14, 2020 | 11:36 AM
MelWff's Avatar
MelWff
The 1969 Chevrolet Chassis Service Manual in the Engine Electrical section in the back of the manual states for the original Delco coil the primary resistance is between 1.77 and 2.05 ohms.
The secondary resistance is between 3,000 and 20,000 ohms.
Old Apr 14, 2020 | 11:52 AM
Sammy T's Avatar
Sammy T
I saw that, but Willcox had stated different values, particularly for the secondary where Ernie said that less than 11k was a problem.
Otherwise, my coil is in spec. Maybe a little weak on spark, but in spec.
Old Apr 15, 2020 | 05:19 PM
Sammy T's Avatar
Sammy T
Got a standard replacement from one of our vendors. The freakin thing was blue. Blue! Why? Website showed black. Anyway, testing that coil. Primary 1.7. Secondary 8100. Still wondering why Willcox stated 11k or less is bad.
Old Apr 15, 2020 | 08:42 PM
MelWff's Avatar
MelWff
Is the blue coil a Standard Motor Products coil?
Old Apr 15, 2020 | 09:35 PM
Sammy T's Avatar
Sammy T
yes
Old Apr 16, 2020 | 07:50 AM
wilcar's Avatar
wilcar
Originally Posted by Sammy T
yes
The blue streak SMP coil has been their performance coil for many years. I use them on 2 vehicles currently.
Old Apr 16, 2020 | 10:23 AM
Sammy T's Avatar
Sammy T
it’s not the blue streak. Black top, kind of a Laguna blue body.
To Ignition Coil Specifications?
