Speedometer gear
Old Apr 17, 2020 | 03:28 PM
7t9l82's Avatar
7t9l82
Default Speedometer gear
My Speedometer reads 4 M.P.H slow at every speed. I have 3-55 gears and a 275-60-15 drag radial on the rear, I'm thinking about a speedometer gear for a 336 rear would get me closer to the actual speed. Any thoughts?
Old Apr 17, 2020 | 03:33 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
typically, 1 tooth = 5 mph..... so I'd adjust accordingly.
Willcox
Old Apr 17, 2020 | 04:00 PM
7t9l82's Avatar
7t9l82
Willcox
Do you have a recommendation,?
Or a gear that would get me there 1 mph. Faster indicated is better than 4 slower.
Old Apr 17, 2020 | 04:36 PM
HeadsU.P.'s Avatar
HeadsU.P.
Try Speedometer World. They have the color codes for the "driven" gear you need. Might want to put a new seal ( O-ring) on the gear holder too.
Old Apr 17, 2020 | 04:50 PM
7t9l82's Avatar
7t9l82
Thanks.
Old Apr 17, 2020 | 05:57 PM
pspicci's Avatar
pspicci
what trans do you have? i know on my TH400 1 tooth on the driven gear equals about 1.5 mph. i have accumalted several gears over the years due to gear changes and tire changes.
Old Apr 17, 2020 | 07:53 PM
Big2Bird's Avatar
Big2Bird
The gear set calibrates the odometer. When correct, the head is calibrated to the correct speed.
This is optimal of course, as speedo shops are becoming gone with the wind like radiator shops.
Old Apr 17, 2020 | 09:01 PM
7t9l82's Avatar
7t9l82
Mines a turbo 350 I called speedometer world and he said 1 less tooth but I have to count the teeth on the factory gear. I can't believe it isn't listed somewhere.I'm sure every corvette with 355 gears used the same speedo gear in 79.
Old Apr 17, 2020 | 09:11 PM
Big2Bird's Avatar
Big2Bird
TimAT would know how to find that.
Old Apr 17, 2020 | 09:20 PM
7t9l82's Avatar
7t9l82
Thanks I'll try to p.m him.
To Speedometer gear
