C3 LS1 driveshaft
Old Apr 18, 2020 | 07:38 AM
C3LT1's Avatar
C3LT1
Default C3 LS1 driveshaft
My 79 C3 currently has a 94 LT1 with a 4L60E,
new set-up I am swapping a 1999 LS1/4L60E.
what kind of driveshaft do I use for my new set-up?
thanks
Old Apr 18, 2020 | 10:02 AM
nyciti's Avatar
nyciti
You don't need a new shaft, they should align the same unless you move the engine around. They are both the same spline count.
Old Apr 18, 2020 | 04:59 PM
71 Vert LS1's Avatar
71 Vert LS1
Also kind of depends on which engine mounts you use. A lot of folks doing LS swaps are using Dirty Dingo adjustable mounts so they can move the engine forward or back as needed.
Old Apr 19, 2020 | 11:57 PM
bluegtp's Avatar
bluegtp
You don't need a new ds. I had mine shortened. As mentioned above it depends if you get three adjustable motor mounts and where you want there motor to sit, then determine if ds length.
Old May 1, 2025 | 08:13 PM
jr73's Avatar
jr73
…edit
To C3 LS1 driveshaft
