Headlight switch shorting out ?
Old Apr 21, 2020 | 12:49 PM
zrc3john's Avatar
zrc3john
Banned Scam/Spammer
Default Headlight switch shorting out ?
Turned lights on my 73 vette last night....Saw a slight spark on headlight ****.....Dash lights out...Took it for a spin anyway...Was driving and someone pulls up along side of me to tell me I have no tail lights..
Fuse was blown..Changed fuse looked at all wiring underneath....Saw a wire that had power behind radio that had a little copper showing..Taped it up...Everything else looked good, aftermarket radio..
Took it for a drive and after about 15 miles dash lights went out again and had no tail lights once again....Of course fuse blew again...
I changed this headlight switch last summer....
Confused ....????
Old Apr 21, 2020 | 01:25 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
...Headlight switch shorting out?...
Sure sounds like it.
Old Apr 22, 2020 | 06:56 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
Headlight switches and wiper switches are notorious for not lasting. I have a headlight switch from Lectric Limited in there know for about 2 years. The other guys switches lasted maybe one summer, bought same and again one summer. If you want one from a supporter and member, get it from Wilcox. Especially wiper switches. Ernie knows how those switches are.
Old Apr 22, 2020 | 02:06 PM
62corvette's Avatar
62corvette
Why not locate a good original that has lasted about 50 years already?
Old Apr 22, 2020 | 02:47 PM
cv67's Avatar
cv67
St. Jude Donor '05
Standar brand isnt bad...the repops are horrible. Afriad to use mine, its near new and so sloppy afraid it will start a fire.
A good original is tough to beat
These chinese switches are mostly junk.
Old Apr 22, 2020 | 02:56 PM
zrc3john's Avatar
zrc3john
Banned Scam/Spammer
Well, had to order some other parts from mid america ( Eklers wants an arm and a leg for shipping , its a wonder there still in business ) so I just added a headlight switch ...Will see what happens....
Old Apr 22, 2020 | 04:34 PM
Rescue Rogers
my wiper switch is from George 1960FI who has a vette recycling yard. Its been working for 5 years
Old Apr 23, 2020 | 05:38 PM
SwampeastMike's Avatar
SwampeastMike
Look for shorts to ground elsewhere--specifically in the wiring to the tail and parking lights. The flash you see in the switch is because that's where the circuit makes contact just before the fuse pops. The switch body has only +12V wiring and is very well isolated from the grounded mounting bracket so there's very little chance of the switch "shorting out" in a way that blows a fuse.
Old Apr 23, 2020 | 08:34 PM
DHer67's Avatar
DHer67
I had a similar issue with blowing instrument panel fuses. The fuse would blow seemingly randomly when the headlights were on. It turned out that I was missing the bulb under the ashtray, & the socket was not attached to wherever it's supposed to go. The positive contact was bouncing around and would contact a ground somewhere and would short out the fuse. I have a bulb, but it won't stay in the socket unless the socket is clipped in place. And I can't figure out where it goes. I secured it so it can't short out, and the instrument light fuse has not blown since.
Old Apr 23, 2020 | 09:30 PM
jackson's Avatar
jackson
Standard brand
switch DS177 (the cheaper DS177T is just that ...a lesser version
connector S606
To Headlight switch shorting out ?
