cooling fan
Old Apr 24, 2020 | 01:56 PM
trans am kev's Avatar
trans am kev
Default cooling fan
hello all . i am fitting the radiator in my 82 the radiator surround as a fan fitted is this all cooling the 82 needs . i bought the corvette in bits so like building a big puzzle .
Old Apr 25, 2020 | 01:39 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
the efficiency of the cooling system depends heavily on the radiator shroud and the seals around the radiator. The seals help to force the air coming into the radiator, to go through the radiator at driving speeds. The shroud itself is to help the fan crate suction to pull the air through at low speeds.
Old Apr 27, 2020 | 06:35 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by trans am kev
...i am fitting the radiator in my 82 the radiator surround as a fan fitted is this all cooling the 82 needs . i bought the corvette in bits so like building a big puzzle...
The 82 assembly instruction manual (AIM) can be a help for you. It shows the factory installation of the radiator, shroud, seals, fans, etc.
To cooling fan
