Turn signals not working
Old Apr 25, 2020 | 11:35 PM
Daniel Kelley's Avatar
Daniel Kelley
1st Gear
Default Turn signals not working
Hey guys and gals. I need some advice on getting my turn signals working. I have a 79 c3 l-82. The turn signal lever has the cruise control on the end of it. It also switches the high beams. I can pull the lever and the high beam will work, the hazards work also, but the turn signal does not and the flasher does not sound. I have replaced the flasher. I have power at both sides of the fuse for the turn signals flasher.any help will do
Old Apr 26, 2020 | 06:28 PM
papolim's Avatar
papolim
check your new flasher - have had defects right out of box, also check reverse lamps see if they work - sounds crazy but they are on the same circuit as the turn signals, if all good check the turn signal switch for broken wires . good luck.
