Front gas shock Install Trick
Attach zip ties together so they're a slightly larger diameter than uncompressed shock. Place tip of the shock against the inside of the zip tie and push down to compress the shock. Tighten the zip ties once the shock is compressed the desired amount.
Slide the shock through the lower control arm and install bolts.
Cut zip tie and remove.
i wondered why the bottom was u shaped! And not holes..at least thats what i figured out..
