L82 forged piston question
Old May 8, 2020 | 07:00 AM
wilcar's Avatar
wilcar
Default L82 forged piston question
Did the L82 forged pistons use a floating or press fit wrist pin? I see two different rod part numbers, 3946841 for floating pin and 14096846 for press fit pin.
Old May 8, 2020 | 07:55 AM
KenSny's Avatar
KenSny
Press fit for 75,
Old May 8, 2020 | 08:57 AM
stingr69's Avatar
stingr69
All L-82's use a pressed fit pin.
There were very few engines with factory floating pins. Some racing applications used them but street engine applications did not justify the cost.
Old May 8, 2020 | 09:05 AM
wilcar's Avatar
wilcar
Originally Posted by KenSny
Press fit for 75,
So should we assume press fit from 75 and later and floating for 74 and earlier ? Or was it just that the factory just used what they had on a particular day.
Old May 8, 2020 | 09:09 AM
KenSny's Avatar
KenSny
No, see stingr69's post.
Old May 8, 2020 | 11:27 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
The only difference in the pistons is the full floater piston will have grooves for the spiro-locs. You can use them for press fit......
Of course you cannot use press fit for full floater.
These days, they all have spiro-loc grooves as to have just one part number.
Jebby
Old May 8, 2020 | 11:29 AM
stingr69's Avatar
stingr69
Unless your small block is a late '68 to '69 Z/28 302 cubic inch production GM motor, you would not have factory floating pins.
Old May 8, 2020 | 12:29 PM
wilcar's Avatar
wilcar
Got it , thanks for the clarification!
Old May 8, 2020 | 12:31 PM
wilcar's Avatar
wilcar
Jebby
Thanks, appreciate the update! Good info!
Old May 8, 2020 | 04:22 PM
jackson's Avatar
jackson
FWIW, IMO, floaters offer No Performance advantage for street motors.
They, however, really assist motor disassembly/assembly ... and especially dry-fitting/mockup.
Need to swap out a wonky piston or rod ? ... easier.
To L82 forged piston question
