Balancing on inside only ?
Old May 17, 2020 | 03:04 PM
DorianC3's Avatar
DorianC3
Default Balancing on inside only ?
I think I just figured it out. On my 1969, with rings and center caps... you have to balance the rims with weights on inside only, but rings must be on correct ?
And one should not mix the rings up once balanced...
Am I right ?
Old May 17, 2020 | 03:16 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
Am I right ?
I don't believe that's the way it was traditionally done. My car has the clip-on "lead" weights on the rim edge with the stock trim rings fitting over them. I suppose you may get a better balance if the rings are attached but it my not make much difference in real life.
Old May 17, 2020 | 03:19 PM
jeffwebley's Avatar
jeffwebley
No, the weights can be placed on the inside or outside as required BUT, the tire guy needs to place the weights where they won't interfere with the clips that hold the beauty ring on. The clips are spaced 90* apart.
Jeff
If you have aluminum rims, it is common practice to use sticky weights on the inside diameter of the rim itself, as close to the centerline as possible.
Old May 18, 2020 | 04:22 PM
DorianC3's Avatar
DorianC3
Thanks gents. Job done
Old May 18, 2020 | 04:54 PM
PJO's Avatar
PJO
Veteran: Marine Corps
Originally from the factory weights were added to the inside of the rim only. Trim rings the clips started at the valve stem then every 90deg and PO1 and 2's were individual balanced.
Old May 19, 2020 | 01:49 AM
DorianC3's Avatar
DorianC3
Originally Posted by PJO
...and PO1 and 2's were individual balanced.
Sorry but, what do you mean by that ?
Old May 19, 2020 | 05:06 AM
derekderek's Avatar
derekderek
i think he means the PO1-2 wheel covers are so heavy they were balanced separately from the wheel-tire.
Old May 19, 2020 | 05:52 AM
DorianC3's Avatar
DorianC3
ooOOOoooh. I see. It’s a type of wheel cover
Old May 19, 2020 | 09:08 AM
PJO's Avatar
PJO
Yes that is what I was saying. As P01 or 2 wheel covers had to be factory balanced separate from the rim and tire. Special clips were used to balance the wheel cover. If you are restoring these covers they need to reassemble with all the parts in their original location. Or you run the risk of a out of balance situation that may not be able to re-balanced.
To Balancing on inside only ?
