Hood removal and storage?
Old May 18, 2020 | 05:43 PM
Bhebert449's Avatar
Bhebert449
Default Hood removal and storage?
I need to remove the hood on my 69 big block coupe in order to install a Vintage Air kit. I found several old posts on how to safely remove the hood and mark the bracket location for reinstall
my question is how to safely temporarily store the hood. I assume bracket side down and lean against the wall? I am trying to be very careful not to scratch or damage in any way. I know laying flat would be the best but I do not have the floor space.
Old May 18, 2020 | 06:02 PM
teamo's Avatar
teamo
How about ceiling space? I installed hooks on the ceiling and have mine suspended flat above the car on ratchet straps.
Old May 18, 2020 | 06:15 PM
Bhebert449's Avatar
Bhebert449
suspended from 4 corners? How about hanging vertically from the bracket holes?
Old May 18, 2020 | 07:25 PM
johnt365's Avatar
johnt365
I put a shipping blanket on the t tops. Then some foam padding on that and put the hood on the roof.
Old May 19, 2020 | 09:58 PM
TimAT's Avatar
TimAT
I hung my hood on a couple of pegboard hooks for storage. Flat against the wall and no damage. Shipped it to another member after it hung there for a year or so.
Old May 20, 2020 | 04:29 PM
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
I hung mine on the wall like a picture. Used a small wire cable like a picture wire and two hooks.
Old May 20, 2020 | 04:42 PM
derekderek's Avatar
derekderek
looks good there too. I visited Leigh and his vette yesterday.
Old May 20, 2020 | 06:44 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
I got a big heavy duty folding wall mounted bicycle rack , covered the hooks with very thick foam and mounted it to the wall, of course, then covered both the top and bottom of the hood with moving blankets. I then put it nose down on the hooks and used the hood latches to strap it to the wall. Put the hooks of the straps in the latch holes and strung it up to eye hooks in the ceiling. worked great and theats the 3rd time i've put it there
Old May 21, 2020 | 02:22 AM
Bikespace's Avatar
Bikespace
One person removal and installation. I wouldn't use ratchet straps next time, but it worked.
Old May 21, 2020 | 10:59 AM
Rescue Rogers
I built a gantry crane for motor jobs but it works to get the hardtop and the hood off
Old May 21, 2020 | 12:42 PM
KenSny's Avatar
KenSny
I would not suspend all that weight from the corners. You might find the tips not aligning they way they were.
To Hood removal and storage?
