1980 4-Speed Trans Mount Bolt Sizes
Old May 20, 2020 | 02:40 PM
Black72GTS's Avatar
Black72GTS
Default 1980 4-Speed Trans Mount Bolt Sizes
I am having an issue with replacing my trans mount. What size are the threaded holes in the transmission where the mount bolts to it on a 1980 4 speed?
I had trouble getting the old bolts out. There was tension on the bolt all the way until I got it out despite thee being no reason. I figured the PO cross threaded the bolts because one of them was pretty galled up. I am also unable to run a standard die over the threads of those bolts cleanly.
I have two new bolt kits, but one has 7/16-14x1 1/4 bolts, and the other has 3/8-16x3/4...
​​So, which should be correct? Hopefully I don't need to tap new threads...
Old May 20, 2020 | 06:44 PM
Pop Chevy's Avatar
Pop Chevy
2021 C1 of the Year Finalist - Modified
As far as I know they should be 7/16.
Old May 20, 2020 | 10:45 PM
ratflinger's Avatar
ratflinger
NCM Grand Opening Veteran
St. Jude Donor '11, '17
If the bolts galled on the way out then the threads are probably unrecoverable in that aluminum case.
Worst case you can drill out the case and helicoil it
To 1980 4-Speed Trans Mount Bolt Sizes
