Rear alignment - thrust measurement location
I re-did the shims yesterday moving only 1/32 on the passenger and 1/16 on the drivers buy I didn't put the wheels back on as I thought I should pull the pads while I have them off and give them the once over (Ibe got a slight squeak at parking lot speed that I think is a pad complaint ) tomorrow I'll put some goop on and put it back on and go around and try again to see where it is.
If I'm closer I can take it back to the machine for another baseline .
M
Got the rear toe at .156" in Good, happy with that
Both sides are at .5 ~ .6 deg camber with a full tank of fuel (drivers at .7 with my fat *** in the drivers seat)
Got the thrust at .156 off center (measured from each spindle is .3125 different) and I can move it from the drivers side to the passenger side but I can't make it get any better with the 1/32" shims I've got....
Now it's just pissing me off, I've got some stainless shim stock and tomorrow I'm making a couple of .01" shims
(I wonder how many years I drove it at 3/8"+ off center... 10??? 20???)
M
Thrust is .031" off center (a little less than 1/16" difference in reading from one side to the other)
Added a .006" shim to the one side but didn't bother re-checking, close enough for my old eyes. We'll see what the expensive machine say when it goes back in
For future reference, a 1/32" shim moved from one side of one arm to the other changes my readings at the front spindle by about .335 difference from one side to the other or about .167" from the centerline
M
