Best Spark Plug
Old May 26, 2020 | 10:59 AM
BPHORSEGUY's Avatar
BPHORSEGUY
From: SUFFIELD CT USA 2023 C8 CORVETTE UN-MODIFIED FINALIST
Default Best Spark Plug
What is the best spark plug for a 383 stroker motor with 10:1 CR ?
Old May 26, 2020 | 11:28 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
What heads?
How long is the thread?
Gasket or taper seat?
Jebby
Old May 26, 2020 | 11:42 AM
BPHORSEGUY's Avatar
BPHORSEGUY
Originally Posted by Jebbysan
What heads?
Jebby
Dart
Standard
Gaskwt
Old May 26, 2020 | 12:03 PM
BPHORSEGUY's Avatar
BPHORSEGUY
What heads?
Jebby
Dart
Standard
Gaskwt
Old May 26, 2020 | 12:41 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Jebby
Old May 26, 2020 | 12:52 PM
REELAV8R's Avatar
REELAV8R
Agree with Jebby, NGK. I use heat range 5. Absolutely reliable and clean. I just pulled them to clean and they were pristine clean and the gap was still right where I set it at .045”. I use the “V” grove type electrode.
BKR5E to be exact.
https://www.instructables.com/id/Sav...ide-Gapping-S/
look into side gapping plugs, makes ignition of fuel easier/ better.
Old May 26, 2020 | 12:53 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
I have the above card on the wall in my garage
Jebby
Old May 26, 2020 | 12:55 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Be careful because the street plugs are 4-5-6 and the race plugs are 7 to 11 heat range.......
NGK street plugs are fine.....they come in X,R or U depending on the style...I.E. UR4, XR5, FR6.....these plugs are better if you have a high powered sound system
Jebby
Old May 26, 2020 | 01:12 PM
ctmccloskey's Avatar
ctmccloskey
I just use the AC Delco Rapid Fire spark plugs on my high compression 427 in my 1968 C3. They are cheap and they work great with my MSD ignition system.
I used to use the NGK Iridium plugs but did not have great luck getting them to fire in the high compression environment. Maybe it was the .060 gaps I ran with them but they misfired a lot of the time.
The AC Delco plugs were used before the NGK's and ran fine with the big gaps. The plugs would always be nice and golden brown.
Being in the process of getting my Corvette converted to the Holley Sniper Stealth I want to start with a known part. I have the fuel system working now but am getting ready to switch over to the Sniper Ignition system control. I want to enjoy all the benefits this Sniper offers. They say that once the timing is under the Sniper's control that it will use it to get the idle right under all conditions. I want to have the Sniper control everything it can so I get the most out of it. Maybe even get out of the single digits for fuel mileage....
Old May 26, 2020 | 01:13 PM
REELAV8R's Avatar
REELAV8R
Jebby
I have a street plug due to my driving. A racing plug such as 7405 which is heat range 9 would be too cold IMO for the street and self cleaning would likely not take place.
if a guy is racing then yes cold heat range would be appropriate. Street/ strip maybe heat range 7 depending on CR and altitude. But I have been running 5 for years and it has provided the best performance with no detonation. CR 10.6:1 @ 4000+ ft elevation.
Old May 26, 2020 | 03:05 PM
REELAV8R's Avatar
REELAV8R
That's a mighty big gap. I would not be surprised to get a misfire at high RPM and compression with that gap.
Never considered iridium for this type of application. Logic would dictate that a fine wire iridium would fire easier though vs a conventional plug.
To Best Spark Plug
