68 AC question
Old May 26, 2020 | 04:42 PM
dntoearthman's Avatar
dntoearthman
Default 68 AC question
I have installed a new parallel flow condenser , new evaporator, new sanden compressor, new everything, rebuilt the air box ect,
I am having a cooling issue 55 deg at vent and suspect it's the expansion valve, guages read a little high on high side & low on low side.
How long does it take for the guages to balance after system is shut of ?
Takes 15 min for low side to hit 75 w/ high side at 150
30 minutes to balance
Thanks Mike
Old May 27, 2020 | 02:25 PM
68blvert's Avatar
68blvert
Unless its 120° with 100% humidity, 75 is too high on the low side.
Old May 27, 2020 | 03:22 PM
dntoearthman
The system was not running, it was shut off, I just verified I did have a bad expansion valve.
THX Mike
To 68 AC question
