Diff Leak But Not pinion seal
Old May 30, 2020 | 06:44 AM
hdeyong's Avatar
hdeyong
Default Diff Leak But Not pinion seal
I've done a search, but didn't find much.
Has anyone ever had a leak right near the pinion seal, but it wasn't that? I was so sure it was, I bought one, went to start on it today, and it looks fine right around the seal. The oil seems to be coming from slightly above, right around where those two big bolts go through the diff case. Of course, the oil has spread around, and now it's hard to find where its coming from.
Any ideas?
Old May 30, 2020 | 08:19 AM
GTR1999's Avatar
GTR1999
Typically the leak in front of the diff would be from the seal and/or the splines of the yoke. I have found some seals are not as good as others and have stuck with CR/SKF for all differential pinion seals. Also if there is a wear groove in the yoke where the seal rides it will leak. A speedy sleeve is made for that.
Now there is the remote possibility there is a crack in the housing but I think I have only seen 1-2 cracked housings in the 100's I worked on and those were from an internal event over the posi. So I would look at the above areas and that should resolve the problem.
Old May 30, 2020 | 01:52 PM
MelWff's Avatar
MelWff
Did you check the fluid level?
If it was overfilled, could it come out the vent and appear in the area that appears wet?
Old May 30, 2020 | 03:21 PM
kanvasman's Avatar
kanvasman
I have had it come from the yoke itself on some heavy duty trucks I used to run. As said, a grove or just wear and tear with hi mileage.
Old May 31, 2020 | 06:48 AM
JBrooke825's Avatar
JBrooke825
2018 C3 of Year Finalist
A few years ago I noticed oil around the top of the spare tire housing. It was coming
from the vent . I desided to check the oil level in the rear. It was completely full of
oil. Like someone filled the rear when it was not in the car. I think I remember hearing
about this here . I removed all the oil and replaced it with new. No leaks now.
Old May 31, 2020 | 07:55 AM
hdeyong's Avatar
hdeyong
Ok, thanks folks. I've got some new things to check now. I did add oil to it while it was on a friend's hoist. I wonder if the car was tilted forward or backward enough to have me over-filling it.
It's odd, but the pinion seal and both half shaft seals look dry. It seems to be coming from above so the breather is a possibility. I felt around for it quickly, but didn't fine it.
Back at it tomorrow. I've got a whole new dual exhaust system to go on, but don't want it in the way if I have to pull the driveshaft, yolk, etc.
To Diff Leak But Not pinion seal
