Starter relay interlock switch question
Old May 31, 2020 | 01:11 PM
cromwell74's Avatar
cromwell74
Default Starter relay interlock switch question
Hi!
I have a question about the "starter relay interlock switch"
For me this relay/switch has been giving some issues during the last year on my -74 C3....sometimes the car won´t crank at all and then I have to knock on the relay and then the car would start!
Sometimes the car can STOP when I am driving.....CAN this relay/switch cause the car to STOP if it is bad?? Or is the function ment only for when starting the car?
Old May 31, 2020 | 02:09 PM
TimAT's Avatar
TimAT
That relay is supposed to not allow you to start unless the seat belts are fastened. As I recall, it has nothing to do with the run function.
Old May 31, 2020 | 02:31 PM
Peterbuilt's Avatar
Peterbuilt
If you think that the relay is a problem then remove it and install a jumper wire as shown.
To Starter relay interlock switch question
