FAUXRS I KNOW THE PROBLEM
Old Nov 25, 2002 | 08:12 PM
Cali,68,L-79's Avatar
Cali,68,L-79
Default FAUXRS I KNOW THE PROBLEM
Okay dropped off the Vette at http://www.briansclassics.com/ and the car was acting real bad. here's what they found.
1. #4 plug wire burn't by header, why it didn't show on ohmmeter I don't know and #4 plug fouled.
2. Vacuum advance inoperative, completely.
3. Mechanical advance sloppy.
4. Nuetral safety switch bad, mechanic had to bypass, mechanic couldn't get the car started. I have had to push the clutch in several times to start car but thought it was out of adjustment. I told them to leave it bypassed and I'll order it from Ecklers replace it and avoid 3 hours labor.
So given the labor charge to rebuild the distributor I choose to have them install the http://store.summitracing.com/partdetail.asp?part=9605 and replace the #4 plug and wire. Should be ready tommorow. This car is killing me $$$ I don't understand why the ohmmeter didn't catch the wire and plug, I miked them both.
Old Nov 25, 2002 | 08:40 PM
fauxrs's Avatar
fauxrs
Default Re: FAUXRS I KNOW THE PROBLEM (Cali,77,L-82)
Well there is your stumble - I had the same problem I ended up going to NAPA to get the replacement Vacc Advance Cannister - The mechanical advance is always a bit of a problem with me - I wonder if Lars still has mech advance kits for HEI's available.
Old Nov 25, 2002 | 08:41 PM
LAvetteman's Avatar
LAvetteman
St. Jude Contributor
:thumbs:
Great news. Hopefully I will have mine figured out soon. I think Lars has me on the right track.
If you need a vac adv actuator let me know. I have a brand new one for sale.
[Modified by 71,454,4spd, 7:43 PM 11/25/2002]
Old Nov 25, 2002 | 08:58 PM
Cali,68,L-79
Default Re: FAUXRS I KNOW THE PROBLEM (71,454,4spd)
Well after dumping 3.5K on interior, new suspension, leaks etc, etc I didn't want to go buy a whole ditributer as the vac. advance is a cinch however mech advance was screwed, bearings are old, weights are corroded, shims were missing and the springs were corroded and different colors (Bubba). Seems cheaper to get a warrantied new ditributor and not have to ever worry about it again.
David
Old Nov 25, 2002 | 09:05 PM
SLine78's Avatar
SLine78
David,
The mechanical advance springs being different colors may not have been Bubba. Sometime you need to use non matching springs to get the proper advance curve.
Mike
Old Nov 25, 2002 | 09:12 PM
Cali,68,L-79
Default Re: FAUXRS I KNOW THE PROBLEM (SLine78)
David,
Mike
Really? I'm just going off a car Craft article describing the proper use of advance weights and springs. There is a whole butt load of various springs out there on the market which should work for your advance. Different springs would create side loading of the dist. bearings, "non-equal tangental rim force" i.e. more weight on the lighter spring side than on the stronger spring side.
To FAUXRS I KNOW THE PROBLEM
