I'm installing a set of smart struts and found it much easier if I jacked up the trailing arm so that the drive axle was about parallel to the ground (jack up the car first, obviously, and support securely on stationary jack stands).
Then I gently wedged something under the trailing arm at the pivot point where it enters the frame (a wrench socket or piece of wood works well) and removed the jack so I could use the creeper to get under there. I also was replacing my shock mounts so I coated the shock mount and the sides of the strut bushing with a little lithium grease.
Then proceeded to wiggle things in place, swear a little, grunt a little and persuade a little with a LFH (little F*%@in' Hammer)...acutally I used a hard plastic mallet but it's more fun to say LFH. Now taking out the original, rusted shock mount/strut ...that required a BFH ! Good Luck. :D
It sounds like you're installing the stock rods. If the washers are now free,
then install should be fairly easy - as there is some 'slop' in the adjuster.
I replaced with VBP adj struts, and they were tough to twist and wedge into
place. Then you need that LFH to get the bolts in.
I also bought my BFH for those same shock mounts. That was not a happy job. :mad
Oh yeah - I heard that some manufacturers suggest coating the poly bushings
with some kind of compatible grease, so they won't squeak. Polygraphite is
Ok without it - I think.
Install all new camber bolts, and grease up everything, especially the shock mount before re-installing it. Not a ton of grease... just a light coat to help in keeping the rust away!!! A good synthetic grease works for years. Good Luck
Eddie
Start squirting the lower shock bolts a week before the intended swap.Get a torch,a shock bolt removing tool,and a BIG hammer,and a sixer of your favorite brew. You may not need the torch,but you will definately need the brew. :smash: :smash: :smash:
You may want to order new shock bolts just in case. I smashed the bajesus out of mine and that was using the correct shock bolt removing tool and the torch.
