How much G your Corvette pulls?
Old Nov 26, 2002 | 07:51 AM
2BAD's Avatar
2BAD
Default How much G your Corvette pulls?
Mmmm :rolleyes: , stock 1982 Corvette numbers are 0.82 G and 59 mph in 700ft slalom with its ancient white lettered Good Years .
With its neutral weight balance, a C3 can make much better numbers just by switching to hi-tech z rated tires, and with the availability of complete hi performance suspension packages from many Corvette shops, I think that there are more Z06 C3s than the C5 Z06s! :thumbs:
:reddevil Now: bring your G-tics out and see how you're Corvette will
perform and tell us about your suspension mods and tires.
:D :thumbs:
Old Nov 26, 2002 | 11:02 AM
IronJen's Avatar
IronJen
Abby Normal
Veteran: Marine Corps
Default Re: How much G your Corvette pulls? (2BAD)
sold my g-tech so i don't have solid numbers but i'll just guestimate on street tires i pull ~.95, on slicks it's probably more like ~1.1-1.2.
to back that up, these are the mods i've done:
17" wheels/tires
460# springs, cut 1/2 a coil to lower the car 1"
330# rear spring with lowering bolts
all poly bushings
1-1/8" front bar
7/16" rear bar
koni shocks
solid welded the seams on the bottom of the frame
covered and welded many of the holes in the frame
fabricated a third crossmember in-line with flywheel to tighten the framerails
Old Nov 26, 2002 | 02:04 PM
VolVette's Avatar
VolVette
I'm more interested in g's experienced in a 1/4 mile run. Assuming constant acceleration (I realize this is not realistic) in the 1/4, if you reach a speed of 110 mph, you've only experienced about 0.3g's. To maintain a full g of acceleration through the 1/4 you'd have to finish at about 200 mph!
Old Nov 26, 2002 | 05:20 PM
bcwaller's Avatar
bcwaller
C2 of Year Finalist (performance mods) 2019
Default Re: How much G your Corvette pulls? (VolVette)
I have not had much of a chance to measure Gs in the Corvette, but it can outhandle my Chevelle, and that car pulled over 1 G. Running at Willow Springs, Turn 2 is a 470 foot radius turn that I ran a consistent 85-87 mph, with some runs possibly over 90 (I think my speedo is 5% low, so potential speeds up to 95 mph). The math says 1 G to 1.1 G.
As for 1/4 mile G forces, remember that the G force is max at launch, and then drops down as you go down the track and shift gears. You can look at 60 foot times, as well as splits to guesstimate Gs. I've done a little playing with this (a buddy once asked what kind of Gs are pulled in a top fuel run) and have some estimates.
A top Fuel car probably hits about 8 Gs at launch, and might go as low as 3 Gs near the end, and averages about 5 Gs. A 12 second car with a 1.7 second 60 foot time will see a max of maybe 1.25 Gs at launch, then settle down to the 0.8 G to 0.7 G range, averaging 0.6 G for the run.
[Modified by bcwaller, 2:20 PM 11/26/2002]
Old Nov 27, 2002 | 02:21 PM
2BAD's Avatar
2BAD
I'm really impressed with the G numbers :eek: but nobody talked about slalom speed :confused: I think most of us ignore it .Anyway do you think that there are more Z06 C3s than the C5 Z06 ???
:seeya
Old Nov 28, 2002 | 12:45 AM
battsup's Avatar
battsup
Default Re: (2BAD)
i know this is a stupid question but maybe its cause im canadian eh? so wat is ZO6 C3? :confused:
Old Nov 28, 2002 | 07:12 AM
OkeeGuy's Avatar
OkeeGuy
Default Re: (battsup)
im a little confused here...so bear with me if im wrong...
dosnt the C-6 pull 1G?
if that is so...how the heck do our antique C-3's have a chance at even half of that? :confused:
Old Nov 28, 2002 | 07:47 AM
jerryp58's Avatar
jerryp58
What's a Z06 C3? Are we talking about FE7 equipped cars?
FWIW, a 1976 Motor Trend article (other magazines used the same article) on the "new" 1977 Corvette listed the slalom time as 12.5 sec.
I'm a stranger to slalom, so I have no idea what that speed means. The car they tested was an L82 with automatic trans, FE7 option, and GR70x15 radials.
Old Nov 28, 2002 | 06:30 PM
2BAD's Avatar
2BAD
It's not because that somebody is canadian, or because there is a c3 Z06 :D
:lol: it's just because I think that with the reasonably priced suspention kits for c3 Corvettes we can make many c3s handle almost like a Z06
:blueangel: Anybody agrres ???? :crazy:
Old Nov 28, 2002 | 09:07 PM
Chuck Harmon's Avatar
Chuck Harmon
:lol: it's just because I think that with the reasonably priced suspension kits for c3 Corvettes we can make many c3s handle almost like a Z06
:blueangel: Anybody agrees ???? :crazy:
I was once a very vocal proponent of this thought; but, after driving a ZO6 for a year I must concede that I don't think a C3 can be equal to a new ZO6 in the handling department. Tires will get it close, a good driver can overcome the handicap, but everything else being equal, the ZO6 is one incredible handling machine.
Chuck
Old Nov 29, 2002 | 05:19 AM
Darkness's Avatar
Darkness
Default Re: How much G your Corvette pulls? (Chuck Harmon)
Chuck
I must agree with you, but if you want a killer C3 you must change to coil overs, and a revised suspension geometry. Also because of flex, the chassis must be reenforced. And after some more stuff that I left out, then you can compare.
Paul
Old Nov 29, 2002 | 12:56 PM
Chuck Harmon
Default Re: How much G your Corvette pulls? (Darkness)
Paul,
You're right about the suspension geometry. The Guldstrand 5 link will get you very close to the merits of the C5 suspension and will allow coil overs; however, Guldstrand states that the coil overs have to be too short to fit and don't really work as well, certainly not better than the trans-leaf spring.
To stiffen the chassis all you really need is a full roll cage, but you will give up status as a "door slammer" and must now enter and exit Dukes of Hazard style.
Chuck
Old Nov 29, 2002 | 02:25 PM
Roscoe's Avatar
Roscoe
I sure know how many G'sss My Corvetts pull from me.
Every time I fill the car up with gas I say Gezzzz.
Guess we are talking about a different G's
:crazy:
Old Nov 29, 2002 | 10:39 PM
Darkness's Avatar
Darkness
Default Re: How much G your Corvette pulls? (Tom 4108)
I have seen coil overs on C3's but to tell you the truth I dont know if they fit good or not. I think I saw some on ACP's web page. I'll take a look at it :thumbs:
Yes, a roll cage would stiffen teh chassis but the street driver wouldn't want that. Maybe some subframe connectors or so.
Paul,
Old Nov 30, 2002 | 05:49 PM
Darkness's Avatar
Darkness
Or even better change to a C4 suspension setup :yesnod:
http://www.sriiimotorsports.com/page691639.htm
Paul :cheers:
Old Dec 1, 2002 | 05:55 AM
2BAD's Avatar
2BAD
"revised suspension geometry" :smash: That makes think of VBP Performance Plus System .It completly changes the front suspension geometry and revises the rear. :reddevil
Old Dec 1, 2002 | 06:00 AM
2BAD's Avatar
2BAD
cont. VBP Performance Plus System
I forgot, and it will ONLY costs you $$$2000!! :jester
To How much G your Corvette pulls?
Old Dec 1, 2002 | 07:38 AM
jerryp58's Avatar
jerryp58
"I forgot, and it will ONLY costs you $$$2000!! "
What are you looking for; improved performance for FREE or just less than $100.
You can probably get a C3 to handle better than you'd ever need on the street and spend less money than on a new Corvette, but you'd probably never run as well as a Z06, and certainly, 30 years of technological improvement won't come cheap.
Old Dec 1, 2002 | 08:33 PM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Default Re: How much G your Corvette pulls? (jerryp58)
My C3 pulled 20G's !!!
from my wallett.
Old Dec 1, 2002 | 08:35 PM
QuickVet's Avatar
QuickVet
Default Re: How much G your Corvette pulls? (BSeery)
:eek:
