Fouled #8 plug diagnosis
Old Jun 10, 2020 | 07:16 PM
Burgundy 69's Avatar
Burgundy 69
Default Fouled #8 plug diagnosis
I recently managed to replace all 8 plugs and ignition wires on my 69 L-46, with full ignition shielding. I am convinced that most of these cars never had plugs and wires 1, 2, 3 and 4 replaced during tune ups after that experience! Anyway, now that they are all out and have been replaced, I am wondering what can be told about the engine from the condition of the plugs. Most were a dirty gray, I believe due to leaded racing fuel that I have added to the original 11:1 compression engine. You can see this at exhaust too. Plug 8 however, was completely fouled with sticky oil. I do have an oil leak somewhere on the left rear that has managed to soak the starter. I will be replacing the valve cover gaskets with a set of Fel-Pro rubber and steel gaskets this week and hope to solve the leaky oil problem, but how would a leak explain the fouled plug?
Mark
Old Jun 10, 2020 | 07:19 PM
Burgundy 69
Oops, I meant right rear of block.
Old Jun 10, 2020 | 08:44 PM
MelWff's Avatar
MelWff
You make no mention of what plugs, brand and number?
The first thing to come to mind on the plug is valve guide seals.
Old Jun 10, 2020 | 09:19 PM
Gale Banks 80''s Avatar
Gale Banks 80'
Sounds like You have a Oil control problem in the one Cylinder. Best Case is that You have a PCV Valve issue and the Oil is getting sucked in and its running down that Port into that Cylinder. Probably not. Or that Plug Wire or That Plug is dead. Next best is that the Oil Seal on that Cylinder Valves are shot and the Oil is getting in. Worst case is the Rings are shot on that Piston and need to be replaced.
I'd start out with the easy stuff. Does the PCV Valve run into the Intake anywhere near the Port leading to that Cylinder ? If You run the Engine with the old Spark Plug and wire does it sound different if You pull the Plug wire off ? If You pull the Valve cover off You might even see a missing Valve seal or find parts of it. A Borescope looking in the Plug hole will show the top of the Piston. If the Piston is clean with little or no Carbon out near the Cylinder its from Oil leaking by and not letting the Carbon stick.
Old Jun 10, 2020 | 10:16 PM
Burgundy 69
Plugs are AC Delco R43.
Old Jun 10, 2020 | 10:27 PM
Burgundy 69
At this point, I have replaced the plugs and wires. In the process of accessing 1 and 3, I disconnected the exhaust pipe from exhaust manifold, and the ceramic seal cracked and broke, so I am waiting for the new seal before firing up engine.
Engine was rebuilt < 20,000 miles ago, so I am going to cross my fingers on rings/piston.
i am replacing the valve cover gaskets this week (Fel-Pro performance rubber with steel inserts) and will be able to look into the heads. If valve seal is missing or broken, does the head have to come off for replacement? What am I looking for, pieces of rubber in the head?
Old Jun 10, 2020 | 11:00 PM
MelWff's Avatar
MelWff
that is a very cold plug for a stock engine and an extended tip plug would be better, R45S
Old Jun 11, 2020 | 08:59 AM
dennis's Avatar
dennis
My 70 L46 would foul 43's in no time. In fact , r44 is what is called for and they weren't great either. Went with 45's and no issues.
As far as the bad 8 plug, I had that as well . Turned out the shield under the intake was keeping the intake from sealing at the 8 runner. Oil drains back that way. If you've had the block decked,, the head to intake alignment could be off and cause a oil leak among other issues.
Should mention I had the heads worked slightly to breath better to counter any percolating/hot start from running the hotter plug.
Old Jun 11, 2020 | 09:45 AM
HeadsU.P.'s Avatar
HeadsU.P.
You are looking for either a black "O" ring, a black umbrella type rubber chunk or even a blue silicone type of broken seal. Once the broken seal leaves the valve-spring area, it usually travels towards the drain hole at the rear of the head.
You can change valvestem seals easily ON The Head if you have a Valve Spring Compressor Tool. You can get a cheapie for doing one or two valves springs, for around $10. Simple leverage type handle that attaches to the rocker stud / nut. Have a magnet ready for the split-locks.
For doing several springs you will want a better "cam-over" style compressor that allows you to remove springs with one hand, for around $50.
No need to buy a sparkplug air hose for repair on one cylinder. Just shove some soft, flexible rope in the sparkplug hole while raising the piston to TDC.
Old Jun 11, 2020 | 08:37 PM
john 72-04's Avatar
john 72-04
I'm assuming it is running ok because you didn't mention it's running bad. Have you noticed smoke ? At start up...…..extended idle...…….or maybe coming down from high RPM to a traffic light...…..Pretty hard to hurt the lower end of these small blocks but certainly possible. I would start by installing a set of valve seals in it just because they are easy to do first. Then if that doesn't do it put intake gaskets on it....Bet intake gaskets take care of your problem.
Old Jun 11, 2020 | 11:48 PM
Burgundy 69
Thanks to everyone who replied. I will be pulling valve covers this weekend to replace the gaskets and will look for debris. I will let you know how I make out.
To Fouled #8 plug diagnosis
