Electric fan
Old Jun 12, 2020 | 08:37 AM
Steve Kistler's Avatar
Steve Kistler
Default Electric fan
Since I don’t have heat or air but have circuit in place,is there an easy way to just hook up auxiliary cooling fan to manually use fan on the days she runs a little warm. Thanks
Old Jun 12, 2020 | 09:27 AM
interpon's Avatar
interpon
I leave mine on all the time..or connect the temp switch? I connect the 2 wires at temp switch..completes the ground on a 79
not sure what you have already..year etc..
Old Jun 12, 2020 | 10:37 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
My electric fan just requires a ground so if the switch supplies power ,it won’t work. You could run a wire to the switch then ground the other side and it will work
Old Jun 12, 2020 | 11:11 AM
Steve Kistler
I just thought if you could use the circuit that has the heat/ac fan and use the fan speed switch to manually operate it would make for a slick setup on my 79-L82. Just kicking around ideas. I figure there is already power,ground and a relay in place so I should be able to disconnect blower motor and hook fan to that if amp draw is similar. If not then I will just get a kit. Thanks for replying
Old Jun 12, 2020 | 11:20 AM
Rescue Rogers
No, the cooling fan might be as high as 3 times the amount the heater fan consumes. So you”ll have to run new wires and a bigger breaker and if possible, a fan controller is even a better idea As it will slowly ramp up your fan and
use less power to monitor the temperature. I use Deraile
Old Jun 12, 2020 | 11:53 AM
Steve Kistler
Thanks, when I bought the car someone had burned the engine harness and I replaced it so will just get a switch and relay kit and do it right.
To Electric fan
