Spark Plug Wire Size
Old Jun 12, 2020 | 03:57 PM
Beeveh's Avatar
Beeveh
Cruising
Default Spark Plug Wire Size
Currently rolling with some 7mm spark plug wires in my 69. Got gifted a new set of 8mm wires and was wondering if they’ll work. Thanks!
Old Jun 12, 2020 | 04:04 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
8mm will not fit your stock wire looms if you're still running those.
Old Jun 12, 2020 | 04:38 PM
69lemans's Avatar
69lemans
I run 8.5's on my 69 through all the stock shielding's with no issues. I do however have after market Valve cover holders.
Old Jun 12, 2020 | 04:43 PM
MelWff's Avatar
MelWff
Exactly what benefit will you be getting versus the labor in replacing them?
Are they both some type of spiral core wire as opposed to solid copper?
What has been done to the rest of your ignition system, in particular the cap, rotor and coil?
To Spark Plug Wire Size
