79 with strange electrical issue
Old Jun 16, 2020 | 09:19 PM
N31596's Avatar
N31596
Cruising
Default 79 with strange electrical issue
I am getting a draw on my battery on my 79. That battery goes dead pretty much overnight. My gauges(volt meter) are reading even with the key out. If I pull the fuse for the gauges I loose the draw. I used the test light method to confirm this. I have replaced the ignition switch to no avail. Another strange thin is my brake light(the one in the center of the cluster) comes on when I am cranking the engine. I have put in a battery disconnect , but I would like to fix this properly as I have gave my vette to my daughter and I don’t want her to have to deal with that issue. Any ideas where to look would be great. Thanks, in advance.
Jason
Old Jun 16, 2020 | 09:31 PM
henrikse's Avatar
henrikse
When you pulled your fuses and lost it you should have put back 1 at a time until the draw came back and that identifies the circuit drawing current. Then with wiring diagram you can start opening this circuit to find trouble
Old Jun 16, 2020 | 09:43 PM
N31596's Avatar
N31596
Cruising
I did pull them 1 at a time , it was the gauges fuse that made the draw stop. I just am unsure why the gauge circuit would be getting Power with the key switch in the off position.
Old Jun 16, 2020 | 09:44 PM
bruiser's Avatar
bruiser
St. Jude Donor '15
I would look at the back of the gauge panel. The traces can come loose on the pcb where the main connector plugs in or other places. Just have to super glue them down if they are loose.
Old Jun 16, 2020 | 09:46 PM
Peterbuilt's Avatar
Peterbuilt
Default Hi and welcome!
Have you disconnected the interior light timer. they cause problems.
Old Jun 16, 2020 | 09:57 PM
Big2Bird's Avatar
Big2Bird
N31596's Avatar
N31596
Cruising
Yes, I have disconnected the interior light timer.
Jason
Old Jun 16, 2020 | 10:01 PM
Big2Bird's Avatar
Big2Bird
Aftermarket stereo?
Old Jun 16, 2020 | 10:08 PM
Peterbuilt's Avatar
Peterbuilt
Default Does this help?
https://www.corvetteforum.com/forums...&p=1601687815#
Old Jun 16, 2020 | 10:14 PM
N31596's Avatar
N31596
Cruising
Yes, it is a aftermarket stereo, but it always has been, I have owned this for about 25 years now. I can pull it and check to see if something is back feeding power to the gauges.
Jason
Old Jun 23, 2020 | 09:28 PM
N31596's Avatar
N31596
Cruising
So I removed my radio, disconnected the alternator, and the courtesy light timer has been removed, and I still have a draw. I pulled the center gauges out and once disconnected the draw is gone. I have constant power to the orange wire (the clock) and the pink wire which if I am reading the wiring diagram right goes to the seat belt/ key warning buzzer and the gauges fuse. Is that circuit supposed to have constant power? I have 2 79s and my other one doesn’t have power to the gauges with the key off. I am also still trying to figure out why my brake light comes on when cranking over also. Any suggestions?
Jason
Old Jun 23, 2020 | 09:55 PM
Big2Bird's Avatar
Big2Bird
Jason
(Disclaimer. Without looking at your wiring in person, and having the correct schematic in front of me, I am "educated guessing.")
Gauge fuse should be off with key. Maybe key switch?
Drain? disconnect the negative post on battery. Place any 12 volt test light between the wire and battery post.
Pull ALL fuses. Light will be out (you hope).
Add fuses until light goes on. Pull that one out and add others until they are all in but the draw(s).
I take out drivers seat for this recreational activity. 4 nuts,done.
Old Jun 23, 2020 | 10:19 PM
N31596's Avatar
N31596
Cruising
I have replaced the ignition switch, I lose the draw when I pulled the gauge fuse, but I stopped at that point. I will pull the rest as you suggest.
Jason
Old Jun 23, 2020 | 10:25 PM
Big2Bird's Avatar
Big2Bird
I would verify it's ONLY the gauge fuse with a light or a meter.
Old Jun 23, 2020 | 11:06 PM
Peterbuilt's Avatar
Peterbuilt
Default Another guess
Is the anti-theft relay disconnected?
Old Jun 26, 2020 | 09:41 PM
N31596's Avatar
N31596
Cruising
This comes off of the gauge fuse in the fuse block, can anyone tell me where this pink wire in the engine compartment.
thanks, Jason
Old Jun 27, 2020 | 12:23 AM
bruiser's Avatar
bruiser
St. Jude Donor '15
That pink wire goes to the coil
Old Jun 27, 2020 | 09:34 PM
N31596's Avatar
N31596
Cruising
That’s what I thought, just wanted to confirm.
Jason
To 79 with strange electrical issue
