How to adjust an adjustable shift fork ball?
Old Jun 17, 2020 | 08:46 PM
Corvettedave02's Avatar
Corvettedave02
C3. 427, 4-link, c7 z06
Default How to adjust an adjustable shift fork ball?
Hello all. I would like to reduce the pedal travel if possible or at the very least get the clutch pedal engagement closer to the floor so my knee doesn’t bang the steering wheel as easily.
can an adjustable shift ball help with this?
lakewood housing. Stock 4 speed linkage and fork. Putting a McLeod dual disc clutch in. 76 Vette. Tremec TKO.
Old Jun 17, 2020 | 09:47 PM
Big2Bird's Avatar
Big2Bird
I think Lars did a thing on that.
Old Jun 18, 2020 | 11:14 AM
Corvettedave02
Ok thank you. I’ll check
Old Jun 18, 2020 | 02:45 PM
TimAT's Avatar
TimAT
Centerforce has a pretty good bit of info on their website too. You need to measure the thickness of the flywheel. then the distance from the block face of the housing, including the block plate, to the top of the pivot ball. A little math will tell you how much taller or shorter your pivot needs to be.
Old Jun 19, 2020 | 03:29 PM
Corvettedave02
Thank you. Very helpful.
Old Jun 19, 2020 | 03:39 PM
Big2Bird's Avatar
Big2Bird
Don't install the ball backwards.
Old Jun 19, 2020 | 04:04 PM
Corvettedave02
I think I’ll get this one installed correctly, lol
Old Jun 19, 2020 | 05:16 PM
69ttop502's Avatar
69ttop502
With a Lakewood and block plate, you probably will need an adjustable ball. I liked the McLeod better than the Lakewood ball. I would mock it all up with the clutch and bellhousing installed. Put the ball in and put the fork and bearing on and pull the fork until the bearing contacts the pressure plate. Adjust the ball until you have a 5-7 degree forward angle on the fork when the bearing contacts the pressure plate. Do this a few times to get it right. I used two pieces of coat hanger, one on the face of the bell-housing and the other on the back of the fork where it hits the ball to visualize this forward angle. If stock, you should have the 1.25 inch bearing. Don’t cut the excess off the adjustable ball until you get it set as you want it close to the bottom of the hole as they tend to work loose. Use red Loctite on it. Not corvette, but this is a great thread with some very knowledgeable people on it.
https://www.chevelles.com/forums/33-...ivot-ball.html
Old Jun 19, 2020 | 05:26 PM
69ttop502's Avatar
69ttop502
By the way, just put the McLeod RST in mine and love it if that is the one you are going to use.
Old Jun 19, 2020 | 06:35 PM
Corvettedave02
Thank you! I got the McLeod rxt. Probably will chatter a bit I expect but I want to be prepared for future upgrades, lol.
Old Jun 22, 2020 | 09:27 PM
Sky65's Avatar
Sky65
St. Jude Donor '05, '09, '15
If C3s do not have this adjustment maybe you could modify your clutch pedal for the C2 bracket.
https://www.corvetteforum.com/forums...djustment.html
Tom
Old Jun 23, 2020 | 09:02 PM
Corvettedave02
that is VERY interesting Tom. I actually have a set of new pedals I am putting in once I get my floor pan cut out and I'll see if there is more than one hole option for a quick release setup.
Old Aug 15, 2020 | 02:01 PM
Corvettedave02
I broke down and ordered the SST hydraulic clutch kit. I think it’s Wilwood based?
They recommended the following Ram part to make pedal height adjustable. https://ramclutches.com/hydraulics-a...s-repair-parts
Old Aug 15, 2020 | 02:04 PM
Corvettedave02
I’m moving the DS floorpans down about 1-2” when I replace it. I’m also going to expand the toe board area forward about 1” or so for legroom since I have to redo the fiberglass where it meets the steel floor pan anyway.
To How to adjust an adjustable shift fork ball?
