Looking into a rear coilover system for my car and stumbled across vansteels kits. (link below for reference) has anyone installed these on their car? and how do you like em?
For a while VanSteel QA1 had a weld-in rear coilover kit for stock trailing arms. -Weld a mount tab on the trailing arm and use the stock location for the bottom of the coilover.
Anyone have any idea what happened to these and whether anyone offers anything like this still?
Seems like it would DEFINITELY be the cheapest way to get rear coilovers on a C3...
You can order them directly from Van Steel a little cheaper (last time I checked) and they also give a forum discount.
Thanks, so they still have them if you call and ask about them, but just don't list them on the website as they're pushing the off-set trailing arms with integrated coil mount as their main solution now?
Sorry Adam,
I clicked on the link in the OP's first post and I was commenting on the price. I have never heard of a Van Steel coilover kit that didn't include new trailing arms.
Lat time I talked to the guys at Van Steel, about 2 months ago, they only offered the rear coilovers as a kit with trailing arms. If someone finds the weld on brackets separate please post where and how much.
I'm no engineer nor am I connected with Van Steel so what I am saying is purely speculation.
On their website, they make an explicit point of letting us know to NOT use the standard arms with coilovers....not even their offset arms that were made for leaf springs. I am assuming that is for a liability reason. Maybe they have seen failures. Maybe they have been sued or are just trying to prevent issueS. I can tell you that the coilover mount on the trailing arm kit is very beefy.
I really don't see those guys as trying to force an upsell to complete arms if they aren't needed. When I ordered mine,, they offered advice on how to save several hundred dollars off what i expected to spend. Give Dan a call. I bet he'll tell you exactly why they don't offer or recommend doing it that way.
You are correct. That is what they told me and I understand. But I already have their heavy duty offset arms arms. I can's see replacing them with the same arms with ones with brackets for what they cost. Maybe they could offer a trade in discount. Also I want to use different coilovers than what they sell.
Things to note on coilover designs for a C3 is where are the spings in relation to the rear axle line. Vansteel its in front of the axle vs ridetech its behind the axle. Some have a angle of the springs very low vs some up right.
Each design has its plus minus. I have the ridetech system with triple (TQ) adjustable shock. No mods required to install. Also allows the rear end to be removed without removing the coilover system.
.......Maybe they could offer a trade in discount. Also I want to use different coilovers than what they sell.
Tom
I think i saw on their website that they do, but I can't find it now. A good set of offset arms should be an easy sell on the forum or Craigslist/Marketplace. (A local sale might be easier than shipping heavy items) I sold all my old suspension parts in less than 10 days for what I expected.
Tom
Here’s the YouTube video from VanSteel’s official channel showing them welding tabs onto the frame for coilovers:
If you search for it, you’ll find a thread with a guy who bought VanSteel trailing arms (the previous version) and the SharkBite rear coilover kit from SpeedDirect and he had a catastrophic failure of the trailing arms. VanSteel blamed SpeedDirect (I tend to agree), SpeedDirect blamed VanSteel, NO ONE covered the parts failure, VanSteel added the disclaimer to their website and offered the guy the new trailing arms at cost but made him pay for it.
The crazy angle and pressures involved in the SharkBit kit seem like a terrible option, IMHO.
A weld-in tab on the frame to mount rear coilovers nice and vertical seems like an ideal cost, performance, longevity trade-off, IMHO. No reason to mandate the extra cost of aftermarket trailing arms if all you’re after is rear coilovers.
Tom
You're in the ideal situation to inquire as to whether they’d make the weld-in option in the video available to you.
QA1 will make custom coilovers available to anyone if you figure out the weld in bracket and placement... I’d be interested in going the same route, honestly if someone figured it out.
I KNOW my VB&P mono spring, new hardware, and in box BILSTEIN B8s would sell in a heartbeat, too. (And make running the rear exhaust way easier.)
They still sell the weld-on brackets and they’re only $17 each! Trying to figure out if they include a template or instructions for placement and whether they sell the appropriate length QA1 coilover or you are supposed to measure and order direct from QA1...
The u-shaped brackets reinforce the upper shock mount. That is a completely separate issue from the lower shock mount on the trailing arm. That lower mount is an L-shape 'bolt' with a D-cut into the body to keep it from rotating. Hanging the coilover from that stock bolt puts a lot of force on the bolt/mount in a ways that it isn't designed to. If the force from the coil over breaks that mounting bolt on one side at highway speeds or on an autocross, the repair bill would probably be much more money than the trailing arms.
Yes the weld on mounts available from VS are upper additional support only. They do not sell the lower mounts welded on their trailing arms. And I understand for liability reasons. However if someone happened to have a set of VS coilover trailing arms and made some cardboard templates of the mounts I would have them professionally made and welded to my arms.
I had a friend with a C2 with the Shark Bite coilover kit welded to heavy duty trailing arms and one of them broke on the HRPT. No one was hurt and car was not damaged but the car went home on a rollback. That design looks way more complicated than necessary and applies allot of rotational force to the trailing arms IMO.
Thanks Jim, I figured I was missing something or they’d already exist.
I keep forgetting that with a coilover all the weight and force is on the shock body and bottom mount.
