1972 Corvette Carburetor
Old Jul 1, 2020 | 04:06 PM
ampelectil's Avatar
ampelectil
Cruising
Default 1972 Corvette Carburetor
I have a 72 Corvette with a small block 350 with 3-speed automatic transmission. Trying to find out the best carburetor for this car. I currently have a Holley, but it's too tall and slow idle is 1100 rpm......plus it's pretty gunked up. Any suggestions?
Old Jul 1, 2020 | 07:36 PM
7t9l82's Avatar
7t9l82
How is it too tall? Can you post a picture?
Old Jul 1, 2020 | 09:55 PM
MelWff's Avatar
MelWff
Rebuild it and correctly adjust the carburetor
Carburetors are all pretty much the same height.
Old Jul 1, 2020 | 10:06 PM
KenSny's Avatar
KenSny
Well thats almost true.
Take a Qjet and Holley 4150. Both measure the same from mounting base to neck flange where the air cleaner sits.
But, from that point up. The Qjet is about 1 1/4" from the flange to the top of the vent tube, where as a 4150 is about 1 11/16:
I'm sure there are other carbs that have taller measuremts - especially above the neck flange.
So we need to hear what carb he has and if there are spacers under the carb. And of course what manifold it sits on.
Old Jul 3, 2020 | 10:37 AM
ampelectil's Avatar
ampelectil
Cruising
I had the engine rebuilt about 20 years ago and had them install a high performance intake manifold. I didn't know it would raise tgine height by around 3/4". The Edelbrock I had in prior was fine.
Old Jul 3, 2020 | 10:52 AM
KenSny's Avatar
KenSny
No real info there. What "high performance" manifold? what Holley is on there? Are there carb spacers?
Why did you swap out the Edelbrock for a Holley?
What does too tall mean? Is the air cleaner hitting the hood? What filter height are you using?
Maybe a picture would help. Blind guessing here at the forum is never productive.
Old Jul 3, 2020 | 02:19 PM
ampelectil's Avatar
ampelectil
Cruising
Sorry. I'm not a mechanic. Had to buy a pancake air cleaner because the original hit the hood with the Holley. Gonna have to see what model it is. I already pulled it out. The reason I 'm replacing it is because it sat too long and the whole carburetor interior is full of white crusty debris from ethanol treated gas. Just looking for a suitable replacement.
Old Jul 3, 2020 | 03:57 PM
knockbill's Avatar
knockbill
Not sure what your intake manifold is,, but I find it hard to beat a properly set up original Q jet....
Old Jul 4, 2020 | 01:47 AM
Mpls Funk's Avatar
Mpls Funk
The research I have done suggests a properly built and set up Q-jet is the ticket. I had a Holley on mine... Just had the original Q-jet rebuilt and definitely looking forward to installing it!
Old Jul 4, 2020 | 03:25 PM
HeadsU.P.'s Avatar
HeadsU.P.
Your Holley model number is stamped on the air horn.
Learn how to rebuild the Holley. They are very easy to work on. A rebuild kit can be had from Summit once you find your model number.
Set the Holley on a large clean towel on your work bench. That will keep little parts from rolling away. Basically you will be washing parts down with Gumout Carb cleaner spray. Then just swap out gaskets as you reassemble.
I suspect you have a spacer or an adaptor under the carb. That is why you have a hood clearance issue.
You may end up with a "Drop-Base" air cleaner to get the clearance you need with a 3" air filter.
To 1972 Corvette Carburetor
