'79 SBC bonding cable for motor
Old Jul 5, 2020 | 03:13 PM
Haggisbash's Avatar
Haggisbash
Default '79 SBC bonding cable for motor
Hi, I was looking at a friends "79 that has some starting issues, looking around the engine bay I can't find a bonding cable or earth strap between the motor and the chassis. Did the '79's have one hidden away on a bell housing bolt or elsewhere? We had no way of lifting the car at his place so was unable to look around underneath.
FWIW the car started perfectly while I was there,looking at the wiring a PO has added a relay to the start circuit from the key switch, I assume the '79's were like my '70 and a direct feed from the keyswitch to the starter originally?
Old Jul 5, 2020 | 03:14 PM
Big2Bird's Avatar
Big2Bird
Look on pass side near the motor mounts
Old Jul 5, 2020 | 03:18 PM
Haggisbash's Avatar
Haggisbash
Thanks, will do, did they jump one across from the chassis to the engine block there? It was hard to see in that area because this car has headers.
Old Jul 5, 2020 | 03:55 PM
MelWff's Avatar
MelWff
Starter to frame.
Old Jul 5, 2020 | 05:12 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
Old Jul 5, 2020 | 05:16 PM
derekderek's Avatar
derekderek
Bonding cable. Boat guy? Comes down to it, any place you can get to the frame and the block you can add the ground cable.
Old Jul 5, 2020 | 05:23 PM
interpon's Avatar
interpon
Old Jul 5, 2020 | 07:28 PM
Haggisbash's Avatar
Haggisbash
Thanks, its definitely not by the starter, the original starter has been replaced with a mini one. I will add cable.
Old Jul 5, 2020 | 07:35 PM
Haggisbash's Avatar
Haggisbash
Well with all that fibreglass they have a lot in common with boats, the only thing missing is the sacrificial anodes to minimise corrosion but come to think of it the zinc die cast water neck acted as one on my '70 when the PO never put corrosion inhibitor in the coolant He figured that because he garaged it all the time it didn't need antifreeze Maybe a sacrificial anode is what the bird cages needed.
Old Jul 6, 2020 | 08:55 AM
derekderek's Avatar
derekderek
and then we can hook it to a cable and drag it behind us on the road for a true ground!
Old Jul 6, 2020 | 09:30 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
I thought the Birdcage was the sacrificial anode!
Jebby
Old Jul 6, 2020 | 05:33 PM
derekderek's Avatar
derekderek
more boat guys on here than i thought...
To '79 SBC bonding cable for motor
