Rear Diff Question
Old Jul 7, 2020 | 03:49 PM
bschuus's Avatar
bschuus
Default Rear Diff Question
I have an 80 automatic and someone gave me a rear diff out of an 80/81 4 speed car and i had it rebuilt. I was wondering if the side yokes needed to be replaced? or am i worrying for for nothing.
Old Jul 7, 2020 | 06:17 PM
MattoonVette's Avatar
MattoonVette
Living the Vette life....
You will probably have to change either the side yokes on the rear end or the yokes on the trailing arm assemblies. They are different sized u-joints on the 80-81 automatics and manual transmission cars. The exception to this is the 82 year, they used the manual side yokes even though they were automatics only. The automatics use a 1330 u-joint on the half shafts and the manuals used a 1350 u-joint. Here is the u-joint measurements for each so you can see what is actually installed.
1330 SERIES UNIVERSAL JOINTS ( 1 1/6"cap X 3 5/8"span )
1350 SERIES UNIVERSAL JOINTS (1 3/16"cap X 3 5/8"span)
Old Jul 7, 2020 | 06:35 PM
bschuus's Avatar
bschuus
I guess I need to order side yokes on the diff. I’m glad I didn’t install it yet
Old Jul 9, 2020 | 01:44 AM
Gale Banks 80''s Avatar
Gale Banks 80'
You need to have a look at what You have first. If the U-joints use 1/4" Bolts its the 1330 and if they are 5/16" then its the 1350's. Obviously the 1350's are more desirable.
Old Jul 9, 2020 | 08:04 AM
bschuus's Avatar
bschuus
I just measured and they are the 1330’s and I’ll be ordering new side yokes for the diff side. Thanks for all your help
Old Jul 9, 2020 | 08:28 AM
MattoonVette
You have the right diff yokes if you measured and they 1330’s.
Are you saying the diff yokes are the 1350’s?
Old Jul 9, 2020 | 11:06 AM
bschuus's Avatar
bschuus
The diff yokes in my re build are 4 speed yokes and the old axles are from automatic
Old Jul 9, 2020 | 11:22 AM
MattoonVette
Got it. Just wanted to make sure.
Old Jul 9, 2020 | 11:35 AM
derekderek's Avatar
derekderek
Don't they also make adapter u-joints with both sizes?
Old Jul 9, 2020 | 11:37 AM
MattoonVette
I believe they do. If he ever planned to add a manual or more power, I would keep the manual diff yokes and change to the manual spindle yokes and the manual half shafts. That is what I did.
To Rear Diff Question
