Starter wires with headers - hi temp or no?
Same question with the red wire. As you see in the photo, right after the fusible link, the wire changes to the type with high temp insulation.
The yellow wire seems to have a yellowish high temp insulation on it (with red typical insulation under it) and I traced it pretty far back and don't see where this was spliced in. This wire has some nicks in it down by the terminal, so I think I will cut a foot or two out and put in some new yellow wire, which will also go inside the high temperature sleeve from summit.
Appreciate any thoughts and suggestions!
ive been noticing a "delayed" start after the engine gets hot. Im assuming its related to my 46 year old wiring harness.
I checked out the wires that are attached to the starter solenoid and they look pretty crusty - not burnt, just old and brittle.
I was thinking about tracing the harness back to the split with heater fan and splicing in new wire.
Thoughts about doing this? Would this cure my symptoms?
Stu
