front coil spring for a big block
Jul 12, 2020 | 09:09 PM
need to replace my big block coil springs anyone have gm part number for theses springs Im pretty sure they were used on other cars threw out the years I just dont want to get hosed cause it says corvette on the box ,,, thanks ,,,
Jul 12, 2020 | 10:20 PM
GM lists two front springs for the 1970 Corvette, one for the 350 and one for the 454...
VIK; page 109
When you get some time, check out the
Vehicle Information Kit for you car here...
https://www.gmheritagecenter.com/doc...t-Corvette.pdf
It is filled with all sorts of information you will find useful regarding your Corvette.
You can also check out this thread, post #4 for some additional part numbers...
https://www.corvetteforum.com/forums...3931826-a.html
Good Luck...
GUSTO
Reason: additional information added
Jul 12, 2020 | 10:35 PM
I still have the original green front spring tags from my 69 427/390 and they are 3931825's.
Jul 12, 2020 | 10:50 PM
Quote:
Originally Posted by
CanadaGrant
Grant, GM lists two front springs for the 1969 Corvette as well, one for the 350 and one for the 454...
VIK; page 117
Interestingly, the specs appear to be the same...
GUSTO
Jul 12, 2020 | 10:53 PM
Jul 13, 2020 | 12:31 AM
However... The part #s changed (according to the GM parts wiki):
3931823 changed to 331316 in Nov. '72
3931825 changed to 331317 in Jan. '73
Also according to the parts look up, there were apparently no other GM products using these parts.
Jul 24, 2020 | 11:21 AM
Cruising
Does anyone know what the height of the 3931825 spring is.
Jul 24, 2020 | 11:25 AM
Check with Zip products. They have exact replacements with the narrow spaced coils on the top.
Jul 24, 2020 | 11:29 AM
You can also check Eaton Springs for OEM replacements.
Jul 24, 2020 | 11:35 AM
Cruising
Thanks, I will check them out.
Jul 24, 2020 | 05:02 PM
