70 LT 1 Lifter Adjustment
Old Jul 15, 2020 | 08:03 PM
pats67copo's Avatar
pats67copo
Default 70 LT 1 Lifter Adjustment
Hi,
I've heard that LT 1 valve adjustment is different from normal valve adjustment procedure and settings
Does anyone know if this is true?
Pat
Old Jul 15, 2020 | 08:32 PM
MelWff's Avatar
MelWff
Google " 30 30 cam adjustment ".
You will find a paper by John Hinckley that has a section on the LT 1.
If after reading it you still have questions, come back here.
Old Jul 15, 2020 | 08:39 PM
pats67copo's Avatar
pats67copo
Old Jul 15, 2020 | 09:49 PM
Dirty Dalton's Avatar
Dirty Dalton
It works very well. I have it on my computer should you be unable to find it.
Old Jul 16, 2020 | 07:04 AM
stingr69's Avatar
stingr69
Originally Posted by pats67copo
Hi,
Pat
Do you have a true GM spec LT1 cam and stock GM stamped steel rocker arms? The revised lash spec is good for that.
If you have aftermarket rockers the procedure is still valid but the lash spec is different.
Old Jul 16, 2020 | 07:50 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
Yes, it’s a solid flat tap pet cam. It needs a lash setting . Read down until you get to the LT1 specs
http://repairs.willcoxcorvette.com/c...ve-adjustment/
To 70 LT 1 Lifter Adjustment
