MSD 6AL 6420 Issue?
Old Jul 25, 2020 | 10:56 AM
Mrvettenick's Avatar
Mrvettenick
Electronics fail from time to time. Nothing is bulletproof. The Pros have a lot of money invested, besides, I would say what they do is rough duty, Hey, you have your opinion, and I have mine.
Old Jul 25, 2020 | 11:06 AM
Big2Bird's Avatar
Big2Bird
Originally Posted by 71chimera
most pro circletrack & roadrace cars w/ big V8 AND that ran carbs & MSD distributors w/ MSD Boxes also ran a redundant system. Crane similar.
One dual pickup aka dual trigger distributor
Two CD boxes that're "Single Action Only" & Selectable (b1 & b2: helps when one of em pukes)
Two Coils that're also "Single Action Only" but are Automatically Selected via One MSD 8210 https://www.holley.com/products/igni...ies/parts/8210
Don't forget, those boxes are hand built, and are NOT the ones you buy at Summit. Yet, they cannot be relied upon to last 500 miles.
Old Jul 25, 2020 | 11:09 AM
Mrvettenick
So are their engines. Do they fail?
Old Jul 25, 2020 | 11:17 AM
Big2Bird's Avatar
Big2Bird
All the time. Your point?
Old Jul 25, 2020 | 11:21 AM
Mrvettenick
If it's man made, it can fail.
Old Jul 25, 2020 | 11:23 AM
Big2Bird's Avatar
Big2Bird
If you want to use an MSD box, by all means.
If you would like an informed opinion, have an open mind.
If you insist on it must be good, everyone uses them, then on that line of thinking:
Ever heard the saying, "Eat ****. 50 million flies can't be wrong?."
Those boxes do make a car idle smoother. No one is disputing that. But reliability suffers. Who idles around town?
Old Jul 25, 2020 | 11:28 AM
Mrvettenick
I've used MSD for 40 years. The only box that failed was the first one that I installed. MSD manned up and fixed it..
Since then, they've been flawless. Now watch one fail on me....thanks!
Old Jul 25, 2020 | 11:31 AM
Big2Bird's Avatar
Big2Bird
I tell people that insist on using them, go ahead, but buy two, and keep one in the car.
That usually prevents failure.
Old Jul 25, 2020 | 11:33 AM
Mrvettenick
That happens with everything...good debating with you! Next issue.......
Old Jul 25, 2020 | 11:51 AM
Big2Bird's Avatar
Big2Bird
I will toss this out there as real world experience:
1) Years ago, we had a member since passed named San Diego Paul.
Lars knew him. He hosted a "Tuning for beers tour."
A year or two after that, I came down and spent the day with Paul. He started his vette, and it was the smoothest idling car I ever heard.
However, after idling for about 5 minutes, it would just "blip" once and awhile.
It was driving poor Paul ape ****.
I told him "Change the box."
NOT the box. It's God's gift to hot rodding. Okay. Whatever.
Two weeks later I get a call. He bought a new box. Issue solved.
2) A close friend is having an issue with ignition. It just seemed funny.
I took my MSD box tester over, and we ran a test. Now you know, the multiple spark crap stops at 3000?RPM.
So we hook it up. RIGHT at the transition from multiple spark to single spark, it broke up.
That was freeway cruising speed for that car. Drove him nutz.
So new box, issue solved.
So, just saying, they have their own issues and symptoms. I like reliability, and for me, they just are not.
Old Jul 25, 2020 | 12:39 PM
71chimera's Avatar
71chimera
Top endurance ranks' motor failures are quite rare; nonetheless, their motors are Not selectable.
When their motor fails, it's obvious & thousands know it; but
but when a selectable box fails, driver simply switches to a backup & no one notices it ('specially when box mfr has a decal on that car)
And as above, the pro teams' cd boxes have been massaged & are more robust than OTS stuff.
e.g. http://www.nelsonspecialties.com/
nick, I hope you have continued good service; and good luck as well
Old Jul 25, 2020 | 12:46 PM
stingr69's Avatar
stingr69
Just some gas for the fire.....Professional racers are not running points. Even though points are supposed to be very reliable....supposed to be more reliable than a MSD.... but those hard headed professional racers with huge piles of money on the line who do demand reliability...insist on running those silly old MSD boxes??? RPM limits I know, but still....
Truth - I have never owned anything from MSD but I do have a 20 something year old Crane box on one car. It was primary current triggered by 1 set of points for many years (never needed any service, dwell settings or points replacements) but I recently went back to a magnetic trigger and will not go back. It idles better and starts easier too. I have more confidence in my ignition RPM than I have in my valve train limits.
LOTS of stuff breaks down on these old cars but still we drive them,
Old Jul 25, 2020 | 01:01 PM
  #33
Mrvettenick
Thanks! You too!
I guess it's all about comfort level. Hey, how many people you know think Corvettes are over over priced POS?
I'm sure you've questioned the Corvette engineers many times by saying "Why did they do it that way?"
Everyone has an opinion based on personal experience.
Old Jul 25, 2020 | 03:37 PM
  #34
dennis's Avatar
dennis
Matt. Sent you a pm.
Old Jul 25, 2020 | 04:27 PM
  #35
Big2Bird's Avatar
Big2Bird
Marketing and accountants.
Old Jul 25, 2020 | 09:46 PM
  #36
Big2Bird's Avatar
Big2Bird
I agree with the mag trigger.
I have points on my Model T. Thats enough.
Old Jul 26, 2020 | 08:12 PM
  #37
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Originally Posted by resdoggie
From my MSD 6530 digital box manual: "The MSD Programmable 6AL-2 Ignition Control will operate on any negative ground, 12 volt electrical
system with a distributor. The MSD can be used with 16 volt batteries and can withstand a momentary
24 volts in case of jump starts. The Ignitions will deliver full voltage with a supply of 9-18 volts and
will operate with a supply voltage as low as five volts."
What are the HEI specs for comparison?
IIRC, HEI is spec'd to operate from 5-16 volts, or 6-16 volts (there was a change to either reduce it to 5v from 6v for better cold weather starts, or a reverse battery protection diode added that raised it to 6v, I can't remember which sequence it was), and also deal with 24v jump starts at lower temps.
To MSD 6AL 6420 Issue?
Old Jul 26, 2020 | 08:25 PM
  #38
69427's Avatar
69427
The big difference is spark duration and spark energy. HEI drops off at 4500. BTW, how many HEI modules take a dump each year? I guess all the people running MSD must be mistaken.
So does your VE. You don't need as much voltage to jump the plugs above your VE/torque peak (that's why a points system keeps all those 327s firing just fine at 7000 RPM). The reduced voltage requirement allows the spark duration to remain sufficiently long for smooth operation.
Old Jul 26, 2020 | 11:18 PM
  #39
Big2Bird's Avatar
Big2Bird
Look at this crap. https://www.ebay.com/i/184354657404?...DefaultOrganic
Old Jul 27, 2020 | 03:05 AM
  #40
Mrvettenick
Well, I know for a fact that my big block starts better, and runs better with about 4 mpg better with the msd in place.. Like I said, everyone has an opinion,
