Won't start, bad choke?
Old Nov 29, 2002 | 02:32 PM
Schmucker's Avatar
Schmucker
Default Won't start, bad choke?
It's 40-some degrees today for a change and I wanted to start the Vette and run it for a little while. I hadn't driven it in about 3 weeks due to excessively cold weather so I figured I better make sure it runs right since I'll have to move it to our other garage to work on it. I cranked on the started and the engine turned over but it wouldn't fire, when I finally got it to fire it was really rough and wouldn't stay running. I couldn't get it much above 600rpm. The whole car was shaking. I'm thinking the choke is stuck or failed.
Old Nov 30, 2002 | 12:57 AM
Schmucker's Avatar
Schmucker
Default Re: Won't start, bad choke? (Schmucker)
ttt
Old Nov 30, 2002 | 09:19 AM
R. Bruno's Avatar
R. Bruno
It sounds like the choke but other things could cause this. Take off the air cleaner lid and take a look. The butterfly that closes over the top of the carb. should be closed when the choke is set. If it isn't your choke is not setting. IF you have a helper, they can hold that butterfly closed (lightly)and it should fire up. If this works, I would say choke. If the choke butterfly IS closed, start to look for vacuum lines that have popped off, spark plug wires that have come loose. I have also had dist. caps crack in just this situation. Cold day - first start up but the cracks are not always noticable. If you have a spare, or havn't replaced in a while, this is a good time to do so if other things check out.
Old Nov 30, 2002 | 03:56 PM
MrAzz74's Avatar
MrAzz74
Also, I'd check the fuel filter just to make sure that's not the problem. Sounds like you're not getting enough gas at idle so it could be that. If not then maybe just a good carb cleaning would do the trick.!! Good-Luck!!
Old Nov 30, 2002 | 08:42 PM
Vetterodder's Avatar
Vetterodder
Active Streak: 90 Days
Sounds like some plugs are fouled, which would explain why it ran so bad once it did start also.
Old Dec 2, 2002 | 09:33 AM
Stewart's74's Avatar
Stewart's74
I had the same problem this fall when the temp dropped. Turned out to be a choke issue with mine. Also, depending on what type of carb you are running, I found out I had a bad accelerator pump in the carb.
To Won't start, bad choke?
