1982 ecm
Old Aug 12, 2020 | 09:59 AM
donaldbly's Avatar
donaldbly
Default 1982 ecm
Where is there an 82 or 84 ecm for my 82..I'm desperate mine is toast
any help will be appreciated!
Old Aug 12, 2020 | 11:16 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Have you tried eBay? Post a Want To Buy here on the forum.
Old Aug 12, 2020 | 02:17 PM
Buccaneer's Avatar
Buccaneer
From: Arizona - If you don’t know CFI, STOP proliferating the myths around it...
You probably won't find either one, or at least at a reasonable price anyway. They are getting harder and harder to find these days. Even if you happen to find one, the chances are good that they have issues as well. I get calls all the time about this subject and I just have them go with the newer GM ECM that will be laptop tuneable when modded. There is a guy that I can turn you onto that has a pretty good starter BIN file for a stock 82 tune that runs well if you decide to go that route and can't find a good ECM. Let me know with a PM if interested. Good luck on your search.
Old Aug 12, 2020 | 03:14 PM
Mrvettenick's Avatar
Mrvettenick
http://bsecorp.com/catalog/ They have been around for a long time.....if you want to go the stock route.
Old Aug 12, 2020 | 03:22 PM
donaldbly's Avatar
donaldbly
Thanks Buccaneer
Old Aug 12, 2020 | 04:21 PM
Buccaneer's Avatar
Buccaneer
Thanks Buccaneer
No problem, just trying to help you out. Also, I just called Blue Streak to see how much they wanted for their Reman made in Mexico ECMs. They do not sell them and you need to go through an auto parts retailer like Autozone according to them, Blue Streak. So, they may or may not have the parts you are looking for, but maybe you will get lucky?
If you do go that route, make sure you mark your chip on one end with a marker or whatever to ensure that you put it in the new ECM the exact same way. If not, and you can put it in backwards with no problem, as soon has you hit the key and power is applied you will instantly fry the PROM and it will be junk. Just a little info for you in case you didn't know that. Good luck.
Old Aug 12, 2020 | 05:01 PM
Mrvettenick
Blue Streak respects the supply chain. You can go through just about any parts store. Whatever you do, do not buy Cardone ecm's.
Old Aug 13, 2020 | 04:53 PM
donaldbly's Avatar
donaldbly
Thanks again could get lucky
Old Aug 13, 2020 | 04:56 PM
donaldbly's Avatar
donaldbly
Thanks Mrvettenick, especially the heads up concerning Cardone
Old Aug 17, 2020 | 07:47 PM
DWAVette's Avatar
DWAVette
Default Any luck?
Did you find an ECM with Blue Streak?
I have an 82 also. It is running fine now, just planning ahead....
Old Aug 18, 2020 | 10:03 AM
donaldbly's Avatar
donaldbly
No, thought I had one located at a dealership in Louisiana this morning but it had already sold... absolutely no luck
in finding an 82 or 84.
Old Aug 18, 2020 | 11:10 AM
Mrvettenick
Sunnit racing has one left....hurry!
Old Aug 18, 2020 | 11:31 AM
donaldbly's Avatar
donaldbly
Called Summit didn't have any they say there are no cores to remanufacture.
Old Aug 18, 2020 | 11:42 AM
Mrvettenick
Try https://www.ecklerscorvette.com/corv...-ecm-1985.html They listed 85, but I would call.
Old Aug 18, 2020 | 01:44 PM
Buccaneer's Avatar
Buccaneer
I did tell you that they ARE hard to find...
Old Aug 18, 2020 | 02:14 PM
gjohnson's Avatar
gjohnson
I bought mine for an 84 at Advance Auto a few yrs ago $85 no core
Old Aug 18, 2020 | 02:17 PM
Buccaneer's Avatar
Buccaneer
Honestly, the best way to go is to go with the EBL Flash II and laptop tune it, for better performance, but that's just me. By doing that, you are already setup for ANY mods you want to do down the road with no issues, just change the tune and go. Also, I can put you in touch with a guy that has a bone stock 82 tune that is plug-N-play and WILL save you a ton of tuning just to get it going and driving.
To 1982 ecm
Old Aug 18, 2020 | 02:18 PM
donaldbly's Avatar
donaldbly
No where to be found now...discontinued everywhere you look
Old Aug 18, 2020 | 02:24 PM
Mrvettenick
Are there any salvage yards close to you. You might be able to search online. Trust me, at the normal scrappage rate there has to be some out there. I wouldn't give up. Most stores wouldn't stock them because of low sales.
Old Aug 18, 2020 | 02:31 PM
donaldbly's Avatar
donaldbly
Looking at salvage yards online you've got to be careful with that a lot of car part scammers out there.
