Lt1 push rod issue
Old Aug 12, 2020 | 05:34 PM
Dave Witman's Avatar
Dave Witman
Default Lt1 push rod issue
Removed a push rod to check it for straightness and now the rod wont go all the way back in. Acts like solid lifter is stuck part way up its bore. Help
Old Aug 12, 2020 | 06:27 PM
Mrvettenick's Avatar
Mrvettenick
Are you sure the rod is sitting in the lifter? If so, try placing that cylinder at TDC compression.
Old Aug 12, 2020 | 08:17 PM
Dave Witman
I am on tdc #1 so 8 exhaust is on base circle for adjustment. I think the lifter pulled out of its bore and is laying sideways if that is possible or it is stuck up in the bore.. If I move pushrod up or down it will go in farther but angle is wrong. With pushrod straight it sits about 3/4 inch high.
Old Aug 12, 2020 | 08:27 PM
MelWff's Avatar
MelWff
Did you turn the rod before pulling it out? If not the oil tension between the lifter and push rod can pull the lifter out of the bore.
You may also want to read the LT1 section in this document
http://repairs.willcoxcorvette.com/corvette-30-30-and-other-oem-sb-solid-lifter-cam-valve-adjustment/
Old Aug 12, 2020 | 09:42 PM
71chimera's Avatar
71chimera
you can buy a cheap tiny endoscope inspection camera for your phone or tablet on fleabay amazon for $20 twenty bux
Old Aug 12, 2020 | 09:58 PM
Dave Witman
I know better was distracted when I removed push rod. Nuts. I like the endoscope now I can see my screw up before I remove intake. Will order one tonight. Thanks
Old Aug 13, 2020 | 04:34 PM
71chimera's Avatar
71chimera
with a camera, some stiff wire, patience & prayer; you might be able to wrangle a lifter back into its bore.
Old Aug 13, 2020 | 09:58 PM
7t9l82's Avatar
7t9l82
Look at this as an opportunity to inspect your cam and at least one lifter. You may get it back in with a magnet then find a way to hold tension on the lifter to remove the magnet
To Lt1 push rod issue
