Catastrophic radiator failure
Old Aug 13, 2020 | 02:06 PM
Steve Kistler's Avatar
Steve Kistler
Default Catastrophic radiator failure
The transmission cooler tank ruptured in the radiator cross contaminating both the cooling system on the engine and into my turbo 350 transmission. I pulled the radiator flushed out the engine cooling system and replaced all the hoses and I’m putting in a new radiator. I removed the trans. Pan and filter which looked like a strawberry milkshake and used a hand pump to force as much fluid through return line as I could. I know I can’t empty the converter and am planning to button up and fill with new fluid and repeat . Before I invest in a new transmission I want to try this since it is not a daily driver no big loss. Thoughts? Thanks
Old Aug 13, 2020 | 02:19 PM
Greg's Avatar
Greg
Just another Corvette guy
It's certainly worth a try Steve.
I would do it exactly the way you describe and I would expect it to work. You have nothing to lose but the cost of some ATF. If it works out, it saves you the big expense of a trans R & R and overhaul.
Good luck brother.
Greg
Old Aug 13, 2020 | 02:20 PM
walleyfisher's Avatar
walleyfisher
to go the cheep way,
I would at least replace the torque converter, (you do not want whats in the torque converter to go thru the trans), drop the pan, change filter and wipe "sluge" you will find in the pan, and then have your system flushed.
I would be really surprised if the trans was not hurt too though
Old Aug 13, 2020 | 03:57 PM
interpon's Avatar
interpon
happened all the time on honda ridgeline forum and happened to me..the strawberry milkshake of death.. look up honda ridgeline SMOD
if caught soon enough (like it stopped driving) and you pumped most into cooling as opposed to other way...
find exit to radiator from transmission... fill fluid.. start up and let pump into bucket.. a few fill ups.. obviously for not too long, repeat until clean... reconnect and go!!! (filter change)..
mine has been fine...for 10000 miles after..
good luck!!
Old Aug 13, 2020 | 04:45 PM
71chimera's Avatar
71chimera
a little water in motor oil is one thing; water in auto trans fluid quite another.
Friction disks' linings are glued onto disks with a water-based glue (that what's called for when operating in a petro bath). But when water is introduced, the glue softens and linings get shucked off. If you get the water out very quickly you might save it.
Old Aug 13, 2020 | 06:17 PM
Shovels and Vettes's Avatar
Shovels and Vettes
One more reason I like manual transmissions.
Old Aug 13, 2020 | 06:28 PM
RockyL32's Avatar
RockyL32
From: If your not the lead dog the view never changes Boise, Id
Some of the oil change places here have a transmission flush machine. They say it flushes and replaces all the old transmission fluid including the fluid in the torque converter. Might try to tow it to one of those places.
Old Aug 13, 2020 | 07:02 PM
Mrvettenick's Avatar
Mrvettenick
I would run it at idle, and not drive it until the fluid is clear. What you can do is disconnect the trans cooler outlet line that goes to the radiator, put a rubber hose on it into a bucket.
Start the car in park, and let the fluid come out into the bucket. while pouring fresh ATF into the fill tube. When the fluid looks clear, I would stop. It might cost you 2 or 3 gallons, but it's better than pulling the trans. After that, then pull the pan to replace the filter.
Old Aug 13, 2020 | 10:35 PM
interpon's Avatar
interpon
yes this..what i posted..
then change filter..buy cheap fluid til clear
Old Aug 14, 2020 | 11:40 AM
Pa'svette's Avatar
Pa'svette
St. Jude Donor '16-'17-'18,'19
I was the service mgr. at a GM garage in the mid 70's when GM had that problem. The factory required that we pull, disassemble, clean,reassemble and reinstall the trans.
Good luck
Bob
Old Aug 14, 2020 | 11:56 AM
Mrvettenick
Great minds think alike!
Old Aug 14, 2020 | 03:13 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
You might want to look and see if the converter has a drain plug on it.......some of them did!
Jebby
Old Aug 15, 2020 | 07:16 PM
Gale Banks 80''s Avatar
Gale Banks 80'
I used to go to a Trans Shop that drilled and taped every Converter that came into the shop when they did an Oil change. Yes this was before the Fluid changing machines of today. Never did figure out how they Taped the Threads or sealed the Plug but it worked for them. I work in the marine industry and sooner or later we get water ( sometimes salt water) in just about everything that has Oil in it. Very rarely does it require more than fresh Oil. I would do the above mentioned undo the Oil Line trick. You have nothing to loose.
To Catastrophic radiator failure
