Fuel tank cleaner
Old Aug 16, 2020 | 11:32 AM
Big2Bird's Avatar
Big2Bird
Default Fuel tank cleaner
Fuel tank cleaner. Is there such a thing?
Anyone have a recipe?
Old Aug 16, 2020 | 12:19 PM
71chimera's Avatar
71chimera
everyday gum & varnish: common 100LL aircraft fuel has plenty benzene / toluene to dissolve it; as do most track grades.
can even dissolve sock Tshirt
Old Aug 16, 2020 | 12:33 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
Are you talking about adding something to the gas and running it through to clean or are you working with an emptyish tank? My '72's tank needs an empty clean-out and I've been thinking of using rags for the barely 1/2" of old fuel in the bottom followed by acetone.
Old Aug 16, 2020 | 01:38 PM
Big2Bird's Avatar
Big2Bird
Empty tank. Fuel evaporated leaving white residue, which I believe is lead, or additives, or.....
Old Aug 16, 2020 | 01:44 PM
Big2Bird's Avatar
Big2Bird
Lacquer thinner?
Old Aug 16, 2020 | 01:57 PM
71chimera's Avatar
71chimera
Dunno what those hard deposits are; dunno what will dissolve them.
If tank out; perhaps a local blasting jobber w/ shells or their recommended media.
-add-
dunno? but perhaps ? the deposits are nominal for galvanized steel; where the zinc oxide sacrifices itself and is converted to zinc hydroxide and then to zinc carbonate. Dunno? found the below link
https://galvanizeit.org/hot-dip-galv...20environment.
Old Aug 16, 2020 | 02:18 PM
71chimera's Avatar
71chimera
Also, perhaps the white deposit in galvanized steel tank is comparable in both appearance and origin to those white deposits we find in carburetors (which are typically cast of a zinc alloy).
Old Aug 16, 2020 | 03:54 PM
Big2Bird's Avatar
Big2Bird
-add-
Yup. That is the appearance.
Maybe harmless. Maybe it just "pickled."
Old Aug 16, 2020 | 07:58 PM
barkingrats
I've tried all sorts of solvents to remove that carb crust with no success.
Old Aug 16, 2020 | 08:24 PM
DC3's Avatar
DC3
There have been some articles on the web about cleaning gas tanks with muriatic acid and water but you have to neutralize the acid when you're done so you can dispose of it. Never tried muriatic acid for this particular task but it works well to remove hard deposits from toilets, porcelain tubs, etc.
Here is just one article: https://itstillruns.com/clean-out-va...k-6169829.html
DC
To Fuel tank cleaner
