Drag wheel question
Old Nov 30, 2002 | 05:17 PM
nastee383's Avatar
nastee383
Default Drag wheel question
I am thinking about mounting my BFG drag radials on some lite wgt wheels such as draglites or convo pros. Will they clear the brake calipers? I want 15x8 with 4' backspacing, same as the rallys they are currently mounted on. Thanks
Old Nov 30, 2002 | 08:39 PM
garagedweller2's Avatar
garagedweller2
Default Re: Drag wheel question (nastee383)
Eagle Alloys
Old Nov 30, 2002 | 09:21 PM
The Dude's Avatar
The Dude
15" x 8.5" with 3.75" backspacing (I think it is) is as close to your desired spec as you'll get with the Convo Pros. These fit great and look good, too.
Old Dec 1, 2002 | 01:28 PM
The Money Pit's Avatar
The Money Pit
The Draglites have a flat mounting flange which means you will need spacers at least 1/2" thick to clear the brakes. I went with 15x9" with 5 1/2" BS on the rear and run a 1 1/4" adaptor.
To Drag wheel question
