Way back twenty years ago the previous owner rebuilt the engine to make quite a bit more power. After tearing two drivers side poly engine mounts in half he replaced all three mounts with solids. After I bought the car the first time I swapped the transmission mount to poly, as I wasn’t comfortable with everything on solids. I wasn’t getting any vibration, but I had it in my head that I might just crack the transmission case if things twisted enough.
Fast forward to when I sold the car about 8 years ago. That buyer swapped to poly engine mounts and promptly tore the drivers side mount in half under acceleration. He put the solids back on but left my poly transmission mount in place.
Now that I have the car back I’m fixing a bunch of things in hopes of getting it back on the road. Right now my passenger side header is off and I have clear access to the passenger side engine mount. I’m thinking (which is often bad) that I should swap that mount to poly while it’s so easy to get to and just leave the drivers side solid mount in place. The drivers side is the only one which doesn’t seem to be able to handle the torque. That side DOES take all of the pulling force, right?
Is my logic sound or should I just leave both engine mounts solid? And was my initial “fix” of replacing the transmission mount with poly okay?
Use a solid driver side mount only.
Use rubber or poly on pass side & trans.
-add-
poly don't like heat; if real close to header/downpipe, choose rubber instead of poly
-add-
Glad to hear that at least one person thinks I’m on the right track.
Even if some folks don't notice solids' vibration, do any consider what those vibrations are impacting ?
highest performing ICE powered plane used em and most still do (Lord Mount)
doubt creature comfort was much of a consideration during fighter design; surely airframe was.
