So I just picked up a rear differential from a 75 Vette with axle code LR, its a 3.36 ratio. My question is why did they use a LR and AX 3.36 ratio from 71 on up to 75-76?
MelWff Thanks for the info. I tried searching the old threads for the answers but I guess I didn't have the wording correct for it to find what I needed
As you note, AX and LR are 3.36:1 ratio axles and LR is listed from 73-77 while AX is listed from 71-75. Axle were called out as base (standard) axle ratios depending on transmission choice while for that power team, optional ratios were rated as economy or high-performance (high altitude). I would suspect of the two ratios, one was considered for a particular transmission choice while the other...optional. I think its in the shop manuals where these are listed.
LR also goes back to 71. LR is regular 3:36, while AX is heavy duty.
