427 Re Rebuild
Old Aug 24, 2020 | 08:38 PM
Z06CE's Avatar
Z06CE
Default 427 Re Rebuild
I have a question with compression ratio.
Had the 427 rebuilt the 1st time.... had a issue with oil being sucked into the intake ports of the heads. The intake wasn't sealing correctly and the engine was burning oil. The rebuilder is going through the engine again checking everything out. The first rebuild the compression ratio was at 9.3 to 1. Should I have the compression ratio increased closer to 10 to 1. Are there any advantages increasing the ratio or should I leave it at 9.3 to 1.
I know a higher octane fuel will be needed..
But would the engine gain more power or is it a wash if the timing needs retarded to avoid pinging.
Appreciate your experiences.
Old Aug 24, 2020 | 08:57 PM
MelWff's Avatar
MelWff
If you have access to 93 octane 10:1 should be fine.
Old Aug 25, 2020 | 07:04 AM
cv67's Avatar
cv67
St. Jude Donor '05
Add compression, do a good valve job/bowl work to boot youll feel the both combined.
Old Aug 25, 2020 | 07:32 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Compression makes power.
nuff said.
Old Aug 25, 2020 | 07:39 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
.7 of a point of compression at this level is worth about ten horsepower. Lot of money for ten horsepower.
Now there are many other factors as to why you should run more compression...but the big one is the camshaft. Do you have a lot of overlap? Measured compression helps deal with this for the sake of drivability and tuning.
I would leave the compression alone and have the heads done up like a previous poster said......bad *** 5 angle valve job, backcut stainless valves.....and some blending. The way Mark/Vortecpro sets them up......
Is this an oval port closed chamber engine? I had a 427/400 that had a mild dome for 10.3 to 1 and it did not like fuel here in Texas with my curve in it.......closed chambers are that way.
Jebby
Old Aug 25, 2020 | 07:50 AM
Z06CE's Avatar
Z06CE
Jebby
Closed chamber 063 heads. Just thinking of using a thinner head gasket to increase the compression.
in / ex lift is .555 219/227 110+4 LC Hyd roller
Old Aug 25, 2020 | 07:54 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
If the heads and block deck are confirmed flat and the surface isn’t too rough then no harm....you might get about three tenths....
Thought maybe you were thinking of changing pistons, which is not worth it....
Jebby
Old Aug 25, 2020 | 08:47 AM
RatRacer's Avatar
RatRacer
I would leave the compression ratio at 9.3:1. Anything higher is borderline with iron heads and pump gas.
Old Aug 25, 2020 | 07:00 PM
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
Very low duration cam + old closed chamber iron heads...I would leave the compression where it is.
It is the Dynamic Compression Ratio that really matters. which takes into account the cam duration. or IVC pt.
There are calculators online at Wallace Racing and others.
Stay under 7.8-8.0 DCR for street gas on Iron heads or it'll ping bad.
1 point of increase isn't worth the effort for power anyway....
To 427 Re Rebuild
