327 Ported vs. Manifold vacuum
Old Aug 25, 2020 | 01:20 AM
SMV_vette's Avatar
SMV_vette
Default 327 Ported vs. Manifold vacuum
This may be a stupid question or one that's been asked & answered before but here goes...
I'm trying to maximize initial & total timing on my 327. I've reviewed Lars' timing papers & read here that I need to connect my vacuum advance to manifold vacuum. Do I need to add an additional port like the fitting in this pic? I currently have a 400 trans. with power brakes so the current fitting has 2 ports. Thx in advance!!
Old Aug 25, 2020 | 04:22 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Or simply put a T fitting in one of your current vacuum lines. Or look to see if you have an extra port at the base of your carb.
Old Aug 25, 2020 | 06:37 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
what carb are you running. is the rest of the motor stock? What is your initial timing and overall timing?
Old Aug 25, 2020 | 07:13 AM
Rescue Rogers
And check all the little rubber port plugs to make sure they aren’t cracked
To 327 Ported vs. Manifold vacuum
